Guetzli JPEG from Google
WinnieW
Post by WinnieW »
Implement Guetzli as alternative JPEG encoder in Xnview
https://opensource.googleblog.com/2017/ ... coder.html
heimaki
Re: Guetzli JPEG from Google
Post by heimaki »
bg17aw
Post by bg17aw »
Any news on this? When will this be implemented?
It is not even a question of "if", but "when".
bg17aw wrote:Any news on this? When will this be implemented?
As "tools>Export with Guetzli" or "save as>JPEG Guetzli"?
bg17aw
Post by bg17aw »
Thanks, Pierre.
I googled around before posting, but found nothing, you guys should advertise this feature a bit more, it's a good selling point.
I am using the portableapps.com version of xnview and for some reason it is not updating.
Maybe you guys should check it out together with the guys at portableapps to see why? Other apps update fine, though, so I don;t think it is just me.
bg17aw
Post by bg17aw »
hmmm updates manually to 2.40 and still cannot find nothing about Guetzli
Nothing in the "what's new" either.
Nothing in Tools or Save As sections.
Confused by your answer now... can you elaborate a bit? Did you mean this features already exist or were you actually asking me where I would like to see those new features located?
bg17aw wrote:Confused by your answer now... can you elaborate a bit? Did you mean this features already exist or were you actually asking me where I would like to see those new features located?
Pierre is asking where you think it should be located when it is added, I think...
Yes, it looks interesting!
For me Save as... > JPEG Guetzli seems better...
My interest would be to use it to (somewhat) reduce the overall size of large multi-page scans saved with JPEG compression in a PDF, so it would need to be accessable from batch convert.
Another alternative might be to make it available as an option in JPEG -- Settings ??
WinnieW
Post by WinnieW »
Guetzli Update, quality to file size ratio improved
bg17aw
Post by bg17aw »
WinnieW wrote:Guetzli Update, quality to file size ratio improved
Care to elaborate a bit?
Do you mean Google relwased un update?
Or that xnview released an update with Guetzli included?
Thanks
WinnieW
Post by WinnieW »
Google released an Update
WinnieW wrote:Google released an Update
Can you post the link? :D
WinnieW
Post by WinnieW »
heimaki
Post by heimaki »
hm... doesn't work for me. i do not get a file when i save as guetzli.
bege
Post by bege »
It's in the 0.87 change log, but I cannot find it.
I'd love to have it as JPEG save option in the settings
