Keep folders sorted alphabetically
Moderators: cday, XnTriq, helmut, xnview, Dreamer
Foxyrick
Post by Foxyrick » Wed Mar 15, 2017 10:41 am
When I change the sort order of thumbnails in the browser, it would be very useful not to sort the folders by the same criterion, but just keep them sorted alphabetically at the top.
A tick box somewhere in the settings could be used to make the folder sort order 'fixed' at alphabetical regardless of the thumbnail order selected.
Re: Keep folders sorted alphabetically
Post by helmut » Wed Mar 15, 2017 11:00 am
+1 (makes much sense)
This new setting should be active by default, i.e. folders are sorted alphabetically always.. "Name" and "Name (Numeric)" might also affect folders, but all other sort orders shouldn't unless this new settings is unchecked.)
Foxyrick
Post by Foxyrick » Fri Jan 25, 2019 1:45 pm
Still waiting for this... it's the only thing that stops me using XnView MP as my main photo manager.
Post by xnview » Sat Feb 16, 2019 4:27 pm
which sort do you use? folders are sorted alphabetically
Foxyrick
Post by Foxyrick » Fri Mar 08, 2019 10:48 am
I most often use date sort, so the earliest files are at the top and most recent at the bottom (occasionally vice versa).
When I do that, the folders sort in the same order which makes it hard to navigate them from that window. It would be better if the folders could, by way of a settings option, be made to always sort alphabetically. Sorting them in the same way as files rarely makes any sense.
There are a few other viewers and managers I use and all of them have that option. I prefer XnView MP though, over all the graphics managers, except for this one constant irritation.
ETA: I keep checking, every update, to see if it has been added yet ;-)
Post by xnview » Mon Mar 11, 2019 3:15 pm
ok, right it will be changed
Foxyrick
Post by Foxyrick » Tue Mar 12, 2019 8:55 pm
I'll look forward to it, thank you.
Just to be totally clear:
The folders should remain sorted in A-Z alphabetical order at the top of the thumbnails, regardless of what sort method and order is selected for the thumbnails.
Post by xnview » Thu Aug 22, 2019 7:23 am
Foxyrick
Post by Foxyrick » Sat Sep 07, 2019 2:51 pm
That's excellent news, thank you. I look forward to the release.
Post by xnview » Tue Sep 17, 2019 10:15 am
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
