0.84 MacOS: Progress bar "Updating catalog" is stuck
Bugs that are confirmed but cannot be fixed for some reasons.
dandv
Post by dandv »
I have a folder with 66,000 files across a few hundred directories. I've deleted the thumbnails cache because the Categories were filled with tag spam that came from images outside that folder I wanted to focus on, and then I selected all that folder's files and directories in Browser, and ran View -> Update catalog from files.
The progress bar has been stuck at the very beginning of the progress bar for about an hour. Not even the slow digiKam should take that long.
Updating catalog stuck.png (10.54 KiB) Viewed 8995 times
Anyway, can some more discrete progress indication be shown, so the user doesn't think XnView MP is stuck? For example, it could show "File X of Y" in the progress bar.
Also, XnView could just be stuck. I'm on Ubuntu, and `lsof | grep xnview" doesn't show any image files being open, only XnView.db and Thumb.db.
dandv
Re: "Updating catalog" is stuck
Post by dandv »
Update: in the meantime the process finished, even though the progress bar was always stuck at that very beginning position.
So please definitely implement a more granular progress bar, maybe updated every 10 files to not spend too much time on the update itself.
CameronD
Post by CameronD »
dandv wrote:Update: in the meantime the process finished, even though the progress bar was always stuck at that very beginning position.
I can confirm the very erratic progress bar, especially in v0.84.
In some tests (0.84) it has stayed stuck on zero for a long time (maybe 20 or 30 minutes), then I noticed it had jumped to 60%, I turned away briefly and when I turned back almost immediately it was finished.
My tests with v0.85 beta 1 indicated more even progress, although it is done with a small number of large jumps. I do not know if the differences between 0.84 and 0.85 beta 1 reflect actual improvement, or if it was just due to the different folders being scanned.
Thanks for your confirming dandv;'s problem, CameronD.
:arrow: Reproduced
CameronD wrote:... I do not know if the differences between 0.84 and 0.85 beta 1 reflect actual improvement, or if it was just due to the different folders being scanned.
@Pierre: Did you make changes in 0.85 test version that might have improved the behaviour of the progress bar?
CameronD
Post by CameronD »
I bit more information on the "progress" bar. I think I have seen why the results are different for different people.
The progress update only seems to happen when the scan goes to the next selected folder.
If I select 5 folders then I will see 5 steps. They are very uneven, because in that example, one folder has far more files than all the other folders combined.
If I select only a single folder, then the progress bar never updates until the end.
This seems to be unchanged in 0.85 beta1.
CameronD wrote:... The progress update only seems to happen when the scan goes to the next selected folder.
Thank you, CameronD, for investigating this more. Basing the progress bar on the number of files processesd instead of number of folders and regular updates (e.g. every 100 files) of the progress bar might solve this.
currently i can't make it on number of all files if you have many subfolders
