Compatiblity with Windows XP
Moderators: XnTriq, xnview
ghmxkd
Post by ghmxkd » Fri Mar 10, 2017 6:29 am
Is XnView 2.39 supposed to run on Windows XP? I"m getting this error:
The procedure entry point _ftol2_sse could not be located in the dynamic link library msvcrt.dll.
Re: Compatiblity with Windows XP
Post by xnview » Fri Mar 10, 2017 10:36 am
is it XP SP3?
TrevorSld
Post by TrevorSld » Wed Mar 22, 2017 6:13 am
Does the Service Pack make a difference? If so I have a computer running SP2.
Post by xnview » Wed Mar 22, 2017 7:50 am
TrevorSld wrote:Does the Service Pack make a difference? If so I have a computer running SP2.
yes, you need SP3 to run XnView
Noel80
Post by Noel80 » Wed Apr 19, 2017 8:37 pm
Same problem with win Xp SP3. (both Xnview and xnconvert)
I found out "the bug" some time ago. It is the last webp plugin. Just replace it with an older one.
I got webp plugin from xnconvert 1.71 and I put it into plugin folder of the last version, and error went away.
webp.zip
(227.74 KiB) Downloaded 145 times
Post by xnview » Mon Apr 24, 2017 6:56 am
Noel80 wrote:Same problem with win Xp SP3. (both Xnview and xnconvert)
Please re-download the package, i've updated the webp.dll
Noel80
Post by Noel80 » Mon Apr 24, 2017 1:04 pm
Now Xnview works fine, thanks!
PS: Xnconvert needs to be updated as well.
