XnRetro - How to launch
More Multi Platform Tools - Windows, MacOSX, Linux
Suzan
Post by Suzan »
The XnRetro icon does not show on my laptop screen after I downloaded the program. What must I do?
Re: XnRetro - How to launch
Suzan wrote:The XnRetro icon does not show on my laptop screen after I downloaded the program. What must I do?
I've never used XnRetro, but downloading it to have a look I think your problem may be that the download is a ZIP file rather than a program installer, so could you please try these steps assuning you are using Windows:
o Double-click on the XnRetro-win ZIP file you downloaded;
o When the folder opens copy the XnRetro folder inside to your desktop (or any other location you prefer);
o Double-click on the XnRetro folder to open it;
o Right-click on the XnRetro application inside and create a shortcut to it (New > Shortcut);
o Copy the shortcut to your desktop (or elsewhere);
o Launch the program using the shortcut.
That's actually quite easy to do despite the number of steps! :D
Suzan
Post by Suzan »
Thank you so much!! I would not have figured that out myself.
