Adding a folder to diashow not working properly
Moderators: XnTriq, xnview
henalWS
Post by henalWS » Sat Mar 04, 2017 8:05 am
When adding a folder to diashow, the pictures are included in the sequence sorted by "Name(numeric)".
Is there a way to select the sort sequence "Name(not numeric)"?
Content of folder Tbild sorted by name(not numerical), Adding this folder to diashow and the resulting filesequence sorted by name(numerical)
Re: Adding a folder to diashow not working properly
Post by helmut » Sat Mar 04, 2017 9:57 am
Thank you for registering to the XnView forum and for your request, henalWS. In the slide show dialog you can sort the images using the "Sort >>" button, but sorting is non-numeric, only.
What you could do is first sort the images in the browser (View » Sort by » Name (numeric)) and then start the slide show. Though this wouldl limit your slide show to one folder.
henalWS
Post by henalWS » Sat Mar 04, 2017 10:47 am
Thank you for your reply, helmut. I have tested to sort the content of the folder with the sort function provided in diashow. This sort function applies only for files which are explicitly included in the diashow. It does not apply to the content of folders included. Is there any possibility to define the sort function on folder basis?
Post by xnview » Fri Mar 10, 2017 3:53 pm
sorry but no way
