0.84: „Special Effects” with Full Screen Mode on two monitors
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
m.Th.
Post by m.Th. » Wed Mar 01, 2017 12:34 pm
Here are some nice steps to follow: (I really don't know if this is a bug...)
0. Have „Use 2nd monitor for Full Screen” checked. Press F11 to enable it.
1. Go to folder F1
2. DblClick on a file to open it in a new tab.
3. Come back to browser
4. Go to folder F2
5. Go to tab opened at step 2.
6. Press F11
Expected: ??? (perhaps to close the Full Screen from the second monitor?)
Actual: !!! (two Full Screen modes on both monitors)
Niceeee! Bug... Feature??
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.90 64bit & XnView 2.00 x64 on Win7 x64 -
m.Th.
Re: „Special Effects” with Full Screen Mode on two monitors
Post by m.Th. » Tue Mar 07, 2017 7:17 am
It is a BUG.
There are a ton of secondary effects which come from here - enough work to fix them.
So: by far the desired Expected: is „to close the Full Screen mode from the 2nd monitor”
m. Th.
Post by helmut » Fri Mar 10, 2017 4:05 pm
Seems like there are few people here with two monitors to reproduce this problem.
:arrow: Reproduced (not reproduced, yet. Perhaps you (Pierre) can reproduce and then fix it).
m.Th.
Post by m.Th. » Fri Apr 28, 2017 7:11 am
Still not fixed in 0.86
m. Th.
Re: 0.84: „Special Effects” with Full Screen Mode on two monitors
Post by xnview » Wed Apr 18, 2018 2:55 pm
are you able to reproduce it with lastest version?
Jochen S.
Post by Jochen S. » Wed Apr 18, 2018 8:27 pm
I can confirm that V0.90 still behaves as described in posting #1.
I did not notice that before and at first I was not sure what I should expect in this case. It can be useful to have these two independent fullscreens. It is a little complicated to activate this mode (which suggests that it might not be a planned feature). But on the other hand nothing is missing or wrong. Another F11 restores the previous state.
Thinking a little more about that I would probably change nothing here.
* F11 while in browser tab enables/disables the fullscreen on the second monitor
* F11 while in image tab enables/disables the fullscreen on the first monitor (no matter if the second monitor is in fullscreen or not)
That's easy to remember, straight forward and sounds like a feature. :wink:
Jochen
Post by xnview » Fri Apr 27, 2018 11:26 am
Post by xnview » Thu Jun 07, 2018 9:40 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
Jochen S.
Post by Jochen S. » Mon Aug 27, 2018 12:49 pm
Can not check since no Linux version 0.91 available.
Jochen S.
Post by Jochen S. » Tue Oct 02, 2018 1:00 pm
XnView MP Version 0.92 under Linux does behave like described here
That's easy to remember, straight forward and I like it this way. From my point of view solved :)
Infi220
Post by Infi220 » Fri Dec 21, 2018 8:51 pm
I heavily relied on the dual monitor full-screen functionality. It even allowed me to browse next/prev photos on each monitor while in full-screen. I'm really disappointed this no longer works. Is it possible to re-add the old functionality as an option in the settings?
