problems/offering to move a file twice
loth
Post by loth »
hi all,
if i doubleclic onto a file/pic in windows explorer and view the file/pic in xnview
and press alt-m to move the file somewhere, the file will be moved to that location but
is still shown in xnview. if i press alt-m again, this message comes up:
this folder have already a subfolder with the same name (<= a last dot is missing, anyway)
if some existing files or folder have the same name than files from folder that you want to copy or move, they will be replaced.
do you want to copy or move this folder?
yes - no - cancel
this is a wrong behaviour, so i report this as a bug :)
loth
Re: problems/offering to move a file twice
loth wrote:hi all,
yes - no - cancel
Yes a :bugconfirmed:
