Windows 10, 64bit
XnView v2.39
After the installation of the current version v2.39, no pdf files can be opened.
Although Ghostscript 9.20 is already installed, it works fine with Ghostview.
Does Ghostview need to be installed as an AFPL Ghostscript or is AGPL-Ghostscript sufficient?
How can the problem be solved.
Xnview has already been installed several times.
After each installation a reboot took place.
Nevertheless, there is the problem.
Thanks and regards Hans
Error if pdf open
Re: Error if pdf open
Could you confirm that you have GhostScript 32-bit installed?Hans Protschka wrote:Windows 10, 64bit
XnView v2.39
XnView Classic, as 32-bit software, can only interface with 32-bit GhostScript and plug-ins even when run on Windows 64-bit ...
cday wrote:Could you confirm that you have GhostScript 32-bit installed?Hans Protschka wrote:Windows 10, 64bit
XnView v2.39
Many thanks!
These was the failure. Now all is ok.
Best regards Hans
