0.84b4: Draw tool: Contents of title bar
In beta 4, the title bar says "Draw [<full path & filename>]".
I think...
...the Draw tool belongs to XnView, so this should be indicated somehow.
...the full path isn't helpful in the Draw tool.
:arrow: I'd suggest to change the title bar to something like "XnView - Draw [filename]".
Re: 0.84b4: Draw tool: Contents of title bar
ok :)
Path has been removed in final version. Prefix "XnView - " is still missing. (A minor issue, but people might be confused if they see "Draw", only.)
EDIT: There's the XnView icon in the top left corner so people should know that this is the Draw tool of XnView.
--> Closed
