[Linux] 0.83 Segmentation fault when starting
mindeunix
Post by mindeunix »
XnView MP fails to start and hard to say whats wrong. GNU gdb output is not useful (missing debug symbols):
#0  0x088fd2ec in ?? ()
No symbol table info available.
#1  0xae599285 in ?? () from /usr/lib/libexpat.so.1
#2  0xae58566d in ?? () from /usr/lib/libexpat.so.1
#3  0xae5874b2 in ?? () from /usr/lib/libexpat.so.1
#4  0xae58a891 in XML_ParseBuffer () from /usr/lib/libexpat.so.1
#5  0xae720f4e in FcConfigParseAndLoad () from /usr/lib/libfontconfig.so.1
#6  0xae713b40 in ?? () from /usr/lib/libfontconfig.so.1
#7  0xae713dbd in ?? () from /usr/lib/libfontconfig.so.1
#8  0xae713e4c in FcInitReinitialize () from /usr/lib/libfontconfig.so.1
#9  0xae83bd37 in ?? () from /home/minde/Downloads/xnview/XnView/lib/libQt5XcbQpa.so.5
#10 0xb72be5f9 in ?? () from /home/minde/Downloads/xnview/XnView/lib/libQt5Gui.so.5
#11 0xb72c0245 in QFontDatabase::findFont(QFontDef const&, int) () from /home/minde/Downloads/xnview/XnView/lib/libQt5Gui.so.5
#12 0xb72c0d1a in QFontDatabase::load(QFontPrivate const*, int) () from /home/minde/Downloads/xnview/XnView/lib/libQt5Gui.so.5
#13 0xb729a6c8 in QFontPrivate::engineForScript(int) const () from /home/minde/Downloads/xnview/XnView/lib/libQt5Gui.so.5
#14 0xb72b584f in QFontMetrics::height() const () from /home/minde/Downloads/xnview/XnView/lib/libQt5Gui.so.5
#15 0x083d258c in ?? ()
#16 0x083ea15b in ?? ()
#17 0x083eb615 in ?? ()
#18 0x080d6066 in ?? ()
#19 0x080d7308 in ?? ()
#20 0x080d9d78 in ?? ()
#21 0x084b11fe in ?? ()
#22 0x084bb574 in ?? ()
#23 0x080af65e in ?? ()
#24 0xb3e9e57e in __libc_start_main () from /lib/libc.so.6
#25 0x080b1bd9 in ?? ()
Strace shows a bit more information:
00:29:39.446571 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000008>
00:29:39.446615 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000008>
00:29:39.446657 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000008>
00:29:39.446693 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000008>
00:29:39.446745 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000009>
00:29:39.446787 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000009>
00:29:39.446824 [b77a5b35] write(5, "\1\0\0\0\0\0\0\0", 8) = 8 <0.000008>
00:29:39.447114 [b77a5b35] inotify_init1(IN_CLOEXEC) = 8 <0.000017>
00:29:39.447163 [b77a5b35] fcntl64(8, F_SETFD, FD_CLOEXEC) = 0 <0.000009>
00:29:39.448035 [b77a5b35] write(1, "ThumbLoaderThread :: stop()\n", 28ThumbLoaderThread :: stop()
) = 28 <0.000012>
00:29:39.448081 [b77a5b35] write(1, "### ThumbLoaderThread :: stop() ok\n", 35### ThumbLoaderThread :: stop() ok
) = 35 <0.000011>
00:29:39.448439 [b77a5b35] write(1, "ThumbLoaderThread :: stop()\n", 28ThumbLoaderThread :: stop()
) = 28 <0.000012>
00:29:39.448476 [b77a5b35] write(1, "### ThumbLoaderThread :: stop() ok\n", 35### ThumbLoaderThread :: stop() ok
) = 35 <0.000010>
00:29:39.449042 [b77a5b35] write(1, "ThumbLoaderThread :: stop()\n", 28ThumbLoaderThread :: stop()
) = 28 <0.000011>
00:29:39.449081 [b77a5b35] write(1, "### ThumbLoaderThread :: stop() ok\n", 35### ThumbLoaderThread :: stop() ok
) = 35 <0.000010>
00:29:39.449214 [b77a5b35] access("/etc/fonts/fonts.conf", R_OK) = 0 <0.000022>
00:29:39.449275 [b77a5b35] stat64("/etc/fonts/fonts.conf", {st_dev=makedev(8, 2), st_ino=6564744, st_mode=S_IFREG|0644, st_nlink=1, st_uid=0, st_gid=0, st_blksize=4096, st_blocks=8, st_size=2305, st_atime=2017-01-05T02:25:23+0200.594991881, st_mtime=2017-01-05T02:26:12+0200.424616056, st_ctime=2017-01-05T02:26:12+0200.424616056}) = 0 <0.000011>
00:29:39.449334 [b77a5b35] open("/etc/fonts/fonts.conf", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 9 <0.000016>
00:29:39.449444 [b77a5b35] read(9, "<?xml version=\"1.0\"?>\n<!DOCTYPE fontconfig SYSTEM \"fonts.dtd\">\n<!-- /etc/fonts/fonts.conf file to configure system font access -->\n<fontconfig>\n\n<!--\n\tDO NOT EDIT THIS FILE.\n\tIT WILL BE REPLACED WHEN FONTCONFIG IS UPDATED.\n\tLOCAL CHANGES BELONG IN 'local.conf'.\n\n\tThe intent of this standard configuration file is to be adequate for\n\tmost environments.  If you have a reasonably normal environment and\n\thave found problems with this configuration, they are probably\n\tthings that others will also want fixed.  Please submit any\n\tproblems to the fontconfig bugzilla system located at fontconfig.org\n\n\tNote that the normal 'make install' procedure for fontconfig is to\n\treplace any existing fonts.conf file with the new version.  Place\n\tany local customizations in local.conf which this file references.\n\n\tKeith Packard\n-->\n\n<!-- Font directory list -->\n\n\t<dir>/usr/share/fonts</dir>\n\n\t<dir prefix=\"xdg\">fonts</dir>\n\t<!-- the following element will be removed in the future -->\n\t<dir>~/.fonts</dir>\n\n<!"..., 8192) = 2305 <0.000014>
00:29:39.449525 [088fd2ec] --- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x1} ---
00:29:40.601674 [????????] +++ killed by SIGSEGV (core dumped) +++
as I understand, segmentation fault happens after XnView MP reads the /etc/fonts/fonts.conf file? The Expat XML validator does not detect any problems.
<?xml version="1.0"?>
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
	Keith Packard
	<dir prefix="xdg">fonts</dir>
	<dir>~/.fonts</dir>
  Accept deprecated 'mono' alias, replacing it with 'monospace'
	<match target="pattern">
		<test qual="any" name="family">
			<string>mono</string>
		</test>
		<edit name="family" mode="assign" binding="same">
			<string>monospace</string>
		</edit>
	</match>
  Accept alternate 'sans serif' spelling, replacing it with 'sans-serif'
			<string>sans serif</string>
		</test>
			<string>sans-serif</string>
		</edit>
	</match>
  Accept deprecated 'sans' alias, replacing it with 'sans-serif'
			<string>sans</string>
		</test>
		</edit>
	</match>
  Load local system customization file
	<include ignore_missing="yes">conf.d</include>
<!-- Font cache directory list -->
	<cachedir>/var/cache/fontconfig</cachedir>
	<cachedir prefix="xdg">fontconfig</cachedir>
	<cachedir>~/.fontconfig</cachedir>
	<config>
  Rescan configuration every 30 seconds when FcFontSetList is called
		<rescan>
			<int>30</int>
		</rescan>
	</config>
</fontconfig>
Moving it solves the problem.
XnView MP - 0.83
Fontconfig - 2.12.1
Expat - 2.2.0
Gentoo Linux-4.9 x86
"Those who deny freedom to others deserve it not for themselves." - Abraham Lincoln
mindeunix
Re: [Linux] 0.83 Segmentation fault
Post by mindeunix »
GDB output again, with debug symbols this time https://p.defau.lt/?s_U0HatCXuGG9Ivxl63SxQ
mindeunix
Post by mindeunix »
PING
sorry but currently i have no Gentoo to test
mindeunix
Post by mindeunix »
xnview wrote:sorry but currently i have no Gentoo to test
Okay, maybe I can test something ?
even with empty fonts.conf file XnView crashes, so maybe worth to try compile different fontconfig version ?
please wait the 0.84 that use new QT version
Do you have tried this build
mindeunix
Post by mindeunix »
Yes, this build works great. Thanks and sorry for late reply (recently updated DKIM, SPF and somehow managed to miss a few new messages).
