XnView MP on Linux Debian 9 Testing Stretch / Sid do NOT RUN
Moderator: XnTriq
delpher
Post by delpher » Wed Jan 04, 2017 3:08 pm
Hello.
Thank you for the best image viewer program at Linux!
After installing of
Linux Debian 9 Testing Stretch / Sid x64
I tryed to install the XnViewMP x64. It installed ok, but it cannot run. After running the app, nothing happens.
This is output of the program from terminal:
xnview/opt/XnView/XnView: error while loading shared libraries: libgstapp-0.10.so.0: cannot open shared object file: No such file or directory
If you know the solution of the problem, I'll be happy to know it. In case of not, maybe you'll fix it later.
Thank you.
Yours faithfully,
Artem L.
Re: XnViewMP on Linux Debian 9 Testing Stretch / Sid do NOT
Post by xnview » Thu Jan 05, 2017 8:03 am
you need to install gstreamer
mindeunix
Post by mindeunix » Fri Jan 06, 2017 9:18 am
Not so simple "install gstreamer". XnViewMP requires the GStreamer version 0.10, which becomes difficult to obtain on modern GNU/Linux systems because GStreamer 0.10 is no longer maintained (GStreamer 1.x has been the main stable series since 2012).
"Those who deny freedom to others deserve it not for themselves." - Abraham Lincoln
delpher
Re: XnView MP on Linux Debian 9 Testing Stretch / Sid do NOT
Post by delpher » Thu Feb 09, 2017 4:30 pm
Solved with last version XnViewMP Version 0.84 x64 (Jan 17 2017) Libformat version 6.95.
Thank you!
