Hi Pierre,
Every time a rectangle, ellipse or text field is added, the opacity setting changes, it is reduced by one.
I have tried for some time, and saw once that at a point the opacity doesn't change anymore, but I cannot reproduce that.
Best regards,
Han
0.84b3: Draw tool: Opacity changes when adding object
- Moderator
Re: 0.84b3: Draw tool: Opacity changes when adding object
Thanks for testing and your bug report, HanVroon.
I confirm this bug.
Important detail: Opacity must be 10 or below.
I confirm this bug.
At this end the opacity value countdown happens at any value below 100.
Just clicking in the image is enough.
I retried several times with deleting the [Paint] section in the ini for a fresh start, between closing and starting XnViewMP.
As long as the opacity value is 100, it stays, otherwise it counts down after every click in the image.
- Moderator
You're right, HanVroon. The problem occurs with any value below 100.HanVroon wrote:At this end the opacity value countdown happens at any value below 100.
- Moderator
Fix in 0.84 beta 4 confirmed.
HanVroon, please let us know in case this problem should still occur for you in 0.84 beta or above.
Just tested in 0.84 beta 4, the opacity value doesn't change anymore, fixed.
Thanks!
Thanks!
- Moderator
Thank you for retesting, HanVroon.HanVroon wrote:Just tested in 0.84 beta 4, the opacity value doesn't change anymore, fixed.
Thanks!
