0.84b3: Draw tool: Outline overlaps with fill
Bugs that are confirmed but cannot be fixed for some reasons.
0.84 beta 3:
In draw tool, the outline and the fill overlap. This leads to a colour mix when using opacity.
1. Open draw tool
2. Insert a rectangle.
3. Set fill colour to red
4. Set Outline colour to blue
5. Set opacity to 60%
-> You will see a red fill, a blue outline, but also a violet outline (mix of red and blue).
Re: 0.84b3: Draw tool: Outline overlaps with fill
yes i know but currently i don't know how to fix it. The outline is always drawn on the shape
