0.84b3: Draw tool: Flickering when opening colour dialog
Moderator
XnView 0.84 beta 3:
In the Draw tool, when double-clicking on foreground or background colour, the Windows dialog for choosing a colour appears. When appearing the "Select colour" dialog flickers several times.
When using single-click the problem does not occur. Please note that this is a minor issue.
Re: 0.84b3: Draw tool: Flickering when opening colour dialog
a single click is enough to open color dialog, there is flickering because a modal dialog is opened
Moderator
xnview wrote:a single click is enough to open color dialog, there is flickering because a modal dialog is opened
I know that single click is enough. But it would be good if there was no flickering because it's somewhat irritating and doesn't make a good impression.
i can't change that, the second click is detected after opened the dialog
Moderator
O.k.. It's a minor issue, so I close this one.
