0.83: Selection with the keyboard controls is inconsistent
Moderators: XnTriq, xnview, Dreamer
jon_joy_1999
Post by jon_joy_1999 » Tue Dec 06, 2016 10:43 pm
When selecting multiple items with the keyboard, using Shift-Left and Shift-Right, selecting an item and then moving with shift-left or shift-right will select an adjacent icon, wrapping the selection when either end of an icon row is reached. Performing the opposite operation (e.g. shift-right after shift-left) will deselect icons.
Starting with the first selected item at the beginning or end of the row of icons, if the next adjacent icon selected is on a different row, then performing the opposite operation the adjacent icon selected is not deselected
For example, if you have 9 icons laid out on multiple lines, for example like
1 a g 2 b
8 l k f
Selecting g, then selecting 2 with shift-right, then deselecting the 2 with shift-left, only g is selected.
The bug is when selecting b, then selecting 8 with shift-right then deselecting 8 with shift left, b and 8 are still selected.
This bug also occurs in reverse order.
Re: Selection with the keyboard controls is inconsistent
Post by helmut » Tue Dec 06, 2016 10:57 pm
jon_joy_1999 wrote:...The bug is when selecting b, then selecting 8 with shift-right then deselecting 8 with shift left, b and 8 are still selected.
:bugconfirmed: Thanks to your detailed description I could reproduce the problem. The important bit is that selection starts at the last thumbnail of the line and wraps into the next line.
jon_joy_1999
Re: 0.83: Selection with the keyboard controls is inconsiste
Post by jon_joy_1999 » Fri Dec 09, 2016 6:15 pm
I can confirm that the bug occurs when the selection starts at the end of the line and wraps to the next line.
I wasn't sure how the bug manifested itself. At first I thought it was inconsistent, because if you shift-right through a bunch of files and then shift-left back to deselect them, the bug doesn't happen, but if you shift-left through a bunch of files then shift-right to deselect it will occur on each row. The important bit that the selection starts at the end of each row is quite enlightening :D
Post by xnview » Mon Jun 12, 2017 8:16 pm
Sorry but i can't reproduce, could you explain more?
jon_joy_1999
Re: 0.83: Selection with the keyboard controls is inconsistent
Post by jon_joy_1999 » Thu Sep 14, 2017 1:31 pm
The bug exhibited in version 0.87 64bits
The bug is on the 3rd frame of the first two images, where the first opposite shift doesn't deselect the selected file
(Large image warning)
Post by xnview » Thu Apr 19, 2018 7:44 am
Post by xnview » Thu Jun 07, 2018 9:44 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
jon_joy_1999
Post by jon_joy_1999 » Fri Jun 08, 2018 5:42 am
Hello! just downloaded XnView MP 0.91 beta and I have confirmed it is fixed in that version, thank you!
