0.84b2: Draw tool: Parameters not updated on selection
0.84 beta 2
When selecting a shape in the draw tool, attributes/parameters like opacity, line style, shadow, outline are not updated.
Instead, when selecting a shape in the draw tool the attributes/parameters should be updated and set to the values the shape currently has.
Note: I'm not 100% sure with the foreground/background colour; but I think the colours should also be set to the colours of the selected shape.
Re: 0.84b2: Draw tool: Attributes not updated on selection
right some parameters are not updated
Re: 0.84b2: Draw tool: Parameters not updated on selection
0.84 beta 3:
More parameters are updated, but foreground and background colour still aren't updated.
helmut wrote:0.84 beta 3:
not sure that foreground/background must be updated
It gets quite confusing if you don't update the colours. An example:
Current fg/bg colours are red/blue. Shape is blue/red.
1. Select the blue/red shape
2. Switch colours --> Nothing happens
ok, i'll change it
xnview wrote:... ok, i'll change it
Good. :)
Fixed in beta 4.
