0.84b2: Draw Tool: Cursor disappears
Bugs that are confirmed but cannot be fixed for some reasons.
0.84 beta2
In Draw tool, when inserting a text and moving the cross cursor around and then stopping, the cursor often disappears.
Re: 0.84b2: Draw Tool: Cursor disappears
strange, i can't reproduce
xnview wrote:strange, i can't reproduce
I found out that this problem only occurs if Windows Setting "Display pointer trail" (fr.: "Afficher les traces de la souris") is activated. I'm not sure whether it's a problem of Windows or XnView MP, perhaps you can try to reproduce and check.
Could someone else please try to reproduce this problem? (To make sure that it's not just a problem on my system).
Moderator & Librarian
helmut wrote:Could someone else please try to reproduce this problem? (To make sure that it's not just a problem on my system).
I use Windows Inverted (system scheme) and wasn't able to reproduce this bug at first, but switching to (None) made the Precision Select cursor disappear. :bugconfirmed:
Thank you for checking, XnTriq.
:arrow: Reproduced
here i don't know why
i don't know how to fix this problem
deus-ex
Post by deus-ex »
Just an idea, I don't know whether this is actually doable:
Can you enforce to disable/ignore mouse pointer trails while the drawing tool is opened? Perhaps by restricting the valid mouse pointer to normal/default shapes only?
