0.84b2: Draw tool: Alignment when changing font size
Bugs that are confirmed but cannot be fixed for some reasons.
Moderators: XnTriq, xnview, Dreamer
In the Draw tool, when inserting a text and then changing the size, the alignment is not taken into account.
1. Start draw tool
2. Insert a vertical line
3. Insert a text
4. Set alignment of text to "Center"
5. Move the text so that the text is centered to the vertical line.
4. Change font size of the text.
--> Position of the text doesn't change and thus the text is no longer centered.
Re: 0.84b2: Draw tool: Alignment when changing font size
you means that the text position need to change so center is not changed, right?
xnview wrote:you means that the text position need to change so center is not changed, right?
Right. When changing a centered text the text is supposed to remain centered to itself (multiline text) and centered to its position.
will be fixed in beta 3
Not fixed in 0.84 beta3:
When changing font size the text box doesn't grow/shrink in the right manner:
- Right aligned text should grow/shrink without changing the most right position.
- Left aligned text should grow/shrink without changing the most left position.
- Centered text should grow/shrink without changing the centered position.
helmut wrote: - Centered text should grow/shrink without changing the centered position.
this one works right?
Yes, for the centered position this works fine (the text remains centered both vertically and horizontally).
i'll change for a future version the 2 others..
