If you reported a bug or requested a new feature please test this version and report any issues in this forum "XnView MP Beta testing".
Please, don't post bugs or request in this topic!
**** Do not re-report a bug reported in this forum which wasn't fixed in XnView MP 0.83 and which isn't in Changelog either ****
You can download XnView MP 0.84 beta 2 here:
Windows x64 ZIP version: http://www.xnview.com/beta/XnViewMP-win-x64-beta2.zip
Thanks for your help!
Changelog 0.84:
1033: [Bugs] Leaks when creating catalog - http://newsgroup.xnview.com/viewtopic.php?f=82&t=34220
1032: [Bugs] Some problems with IPTC-XMP dialog - http://newsgroup.xnview.com/viewtopic.php?f=83&t=34053
1031: [Bugs] Set Rating/category & batch rename - http://newsgroup.xnview.com/viewtopic.php?f=62&t=34110
1030: [Bugs] Move subfolder in same path - http://newsgroup.xnview.com/viewtopic.php?f=82&t=34146
1029: [Bugs] Crash when setting a category and enter something in quicksearch
1028: [Bugs] Crash at start with win10 build 14965 - http://newsgroup.xnview.com/viewtopic.php?f=62&t=34135
1027: [Bugs] 180° rotation on BW picture
1026: [Bugs] 8bf 64bits plugin - http://newsgroup.xnview.com/viewtopic.php?f=82&t=34174
1024: [Bugs] -ini & startup wizard - http://newsgroup.xnview.com/viewtopic.php?f=82&t=33874
1023: [Requests] Mosaic effect missing - http://newsgroup.xnview.com/viewtopic.php?f=82&t=34196
1022: [Requests] Paint feature
1017: [Bugs] Delta Y in Watermark - http://newsgroup.xnview.com/viewtopic.php?f=79&t=34101
1016: [Bugs] 'sort' numeric not default - http://newsgroup.xnview.com/viewtopic.php?f=82&t=34064
1013: [Bugs] 'save as' extension - http://newsgroup.xnview.com/viewtopic.php?f=62&t=34019
1012: [Bugs] 'Save as' doesn't use 'keep date' - http://newsgroup.xnview.com/viewtopic.php?f=62&t=34019
1009: [Bugs] Custom path empty - http://newsgroup.xnview.com/viewtopic.php?f=82&t=33976
1008: [Bugs] Freeze when viewing folder of icon files - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33964
0642: [Bugs] View problem - http://newsgroup.xnview.com/viewtopic.php?f=62&t=31581
0491: [Bugs] View problem - http://newsgroup.xnview.com/viewtopic.php?f=62&t=30721
1007: [Bugs] XnView freeze when closing view of RAW - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33966
0978: [Bugs] MacOSX - edit description crash - resolved.
1005: [Bugs] Slow start & .XnViewSort - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33609
1004: [Requests] afdesign thumbnail - http://newsgroup.xnview.com/viewtopic.php?f=82&t=33948
1003: [Requests] Qt 5.6.2 - resolved.
1002: [Bugs] Problem category rename/move - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33628
1001: [Bugs] Sessions & one instance - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33607
0998: [Bugs] IPTC edit & parent keywords - http://newsgroup.xnview.com/viewtopic.php?f=83&t=33887
0993: [Bugs] Flickr removed - http://newsgroup.xnview.com/viewtopic.php?f=62&t=32077
0989: [Requests] XnView after filename in titlebar - http://newsgroup.xnview.com/viewtopic.php?f=60&t=33762
0955: [Requests] Check for update - http://newsgroup.xnview.com/viewtopic.php?f=60&t=33710
0975: [Bugs] Import with custom filename - http://newsgroup.xnview.com/viewtopic.php?f=83&t=33830
0992: [Requests] No session saved if tabs not used - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33928
0991: [Bugs] Import&sort video files not copied - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33907
0985: [Bugs] FLIF output failed - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33897
0988: [Bugs] Catalog 'Delete' and 'Delete all' don't have same behavior - http://newsgroup.xnview.com/viewtopic.php?f=82&t=33865
0986: [Bugs] Going back to browser doesn't select the good file - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33807
0984: [Bugs] BPG console flicker - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33861
0983: [Bugs] File format color not working - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33870
0982: [Requests] FLIF 0.2 - resolved.
0981: [Bugs] Sidecar naming - http://newsgroup.xnview.com/viewtopic.php?f=82&t=33390
0980: [Bugs] '/' used in copy clipboard - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33833
0979: [Bugs] Export dialog and resampler method - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33867
0977: [Bugs] Parameter for external editor - http://newsgroup.xnview.com/viewtopic.php?f=62&t=33842
0976: [Bugs] Export output folder - http://newsgroup.xnview.com/viewtopic.p ... 9&p=134635
Reason: Fixed broken link
