Add delete file to tool bar or set up the keyboard shortcut
Delete is a frequently used function. Hope that you can make it more handy. Now, I have to right click- delete. That is not so efficient.
Re: Add delete file to tool bar or set up the keyboard short
You can customize XnView's toolbar. Please see topic Delete image button in toolbar? for more details.sibojan wrote:Delete is a frequently used function. Hope that you can make it more handy. Now, I have to right click- delete. That is not so efficient.
By pressing "Del" key you can delete the currently opened image.
Note:
XnView Classic does not support user-defined keyboard shortcuts; XnView MP supports these, only.
Thank you so much. It worked for me very well.
To be honest, XnView Classic is almost near perfect. I believe most people are addictive to that and are reluctant to migrate to XnView MP. In addition, apparently XnView Classic is under more vigorous development than XnView MP. I would not switch to XnView MP in pursue of one or two more features.
