XnView 2.39
XnView 2.39
Dear user,
XnView 2.39 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: CA08E4DFDDF5B603F1359DDCD0F252BD8019A177B424009CDD6812962C4E22E3
XnView-win.zip: 9A5DBD1C12C2E916FAC275E6267057E753193C463B7E834B0CF2F3519067C0F7
XnView-win-full.exe: 8A18294FCA9FAE1501EBCEACE5311F3E5D4904E0FCF2ECCCB09BB74B6C901B56
XnView-win-full.zip: C8ED594A24F2C56DC6454B9858EF115FCF0E4A1903B8F97FDB0549352E10D32F
XnView-win-small.exe: 505C0174E9C3BE182AC71A093ED966434A542337E65541AFB3F679DC813C8AF5
XnView-win-small.zip: 4841259CFDF3CF1EBF8E038823EFB6AAACB52F3ADD4E1A7902D274768F6DDAA7
____ 2.39 Changelog
no IPTC fields in tooltip/info
Thumbnail for blend file
____ 2.38 Changelog
Sort by exif - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32387
Zooming instead file navigation - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33917
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
____ 2.34 Changelog
Delete doesn't work on view mode
Charset in treeview - http://newsgroup.xnview.com/viewtopic.p ... 0&p=127128
Bevel settings - http://newsgroup.xnview.com/viewtopic.p ... 4&p=126724
Sharpen in Resize dialog - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32008
PNG icc profile checking - http://newsgroup.xnview.com/viewtopic.php?f=36&p=127277
alpha channel not copied in clipboard from browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32034
Colors & checksum in Overwrite dialog - http://newsgroup.xnview.com/viewtopic.p ... 6&p=127412
LibPNG 1.6.18
SqlLite 3.8.11.1
NConvert # in filename - http://newsgroup.xnview.com/viewtopic.p ... 2&p=127142
____ 2.33 Changelog
'Use extension' setting - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31619
LIBIMAGEQUANT on 256 colors image - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31567
Long filename - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31586
Clear out of bounds - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31604
Saving in Webp remove 1st pixel
Del during selection - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31760
On some jpeg, EXIF can't be rewritten
____ 2.32 Changelog
User plugin & check extension - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31403
Find similar don't find duplicates
Sharpen thumbnails - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31351
gs subfolder checked - http://newsgroup.xnview.com/viewtopic.p ... 2&p=124739
Customized data/time variables broken - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31367
Batch convert use estimated jpeg quality - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31398
____ 2.31 Changelog
Enlarge zoom quality
____ 2.30 Changelog
NConvert: -embedded_jpeg to extract embedded jpeg - http://newsgroup.xnview.com/viewtopic.p ... 7&p=124337
NConvert: Placeholder for EXIF date modified&date taken in output filename - http://newsgroup.xnview.com/viewtopic.php?f=57&t=29936
$EXIF:DateModified[date format] $EXIF:DateTaken[date format]
NConvert: Extension not forced lowercase - http://newsgroup.xnview.com/viewtopic.php?f=57&t=30294
NConvert: saturation from XnConvert
New addon for upload on ImageShack/Imgur - http://newsgroup.xnview.com/viewtopic.php?f=35&t=25014
Pdf issue - http://newsgroup.xnview.com/viewtopic.php?f=57&t=31292
Rename dialog move top/bottom - http://newsgroup.xnview.com/viewtopic.php?f=34&t=23924
Export dialog remember last folder - http://newsgroup.xnview.com/viewtopic.php?f=34&t=15352
Rotate EXIF orientation only process needed files - http://newsgroup.xnview.com/viewtopic.p ... 4&p=124316
BPG format read support - http://newsgroup.xnview.com/viewtopic.php?f=79&t=31040
File information overlay after reopen - http://newsgroup.xnview.com/viewtopic.php?f=36&t=28540
Placeholder use part of text - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30984
[x-], [x-y], [-y], [x]
Option>Settings>File list>Misc>Exif date used to sort
LockZoom & fullscreen - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31140
GIF Loop Slideshow & Quick slideshow - http://newsgroup.xnview.com/viewtopic.php?f=35&t=29154, http://newsgroup.xnview.com/viewtopic.php?f=36&t=7880
LibQuant for colors reduction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31063
Filter by image & disabled extension - http://newsgroup.xnview.com/viewtopic.p ... 2&p=122226
Alpha channel & enlarge resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30682
Similar files: now you can add files as reference - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30601
Sharpen view - http://newsgroup.xnview.com/viewtopic.p ... 9&p=121277
Change timestamp - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30930
XnShellEx: resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31004
Video gallery only first file used - http://newsgroup.xnview.com/viewtopic.php?f=36&t=23036
Convert Font script - http://newsgroup.xnview.com/viewtopic.php?f=36&t=1332
Non image filename not shown in statusbar - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31018
Similar dialog, use extension in filename - http://newsgroup.xnview.com/viewtopic.php?f=56&t=30908
Back key settting - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30746
PAM format added - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30741
Thumbnail sharpen value - http://newsgroup.xnview.com/viewtopic.php?f=34&t=13348
Autodeskew in toolbar - http://newsgroup.xnview.com/viewtopic.p ... 5&p=119267
Screen dpi on Win 7/8 - http://newsgroup.xnview.com/viewtopic.p ... 6&p=119294
Pause/Play animated gif - http://newsgroup.xnview.com/viewtopic.p ... 2&p=119543
Color picker and greyscale picture - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30215
"Rename all" in OVerwrite dialog - http://newsgroup.xnview.com/viewtopic.php?f=56&t=29151
DDS L8 format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=25507
Settings saved after changes - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30866
Clear in batch convert
Previous focused tab in IPTC dialog - http://newsgroup.xnview.com/viewtopic.php?f=35&t=27902
[IPTC]/PreviousTab
