Example : If I have files :
windows will show 1 -> 2 -> 3 -> 10 -> 11
while xnview will show 1-> 10 -> 11 -> 2 -> 3
is there a way to make xnview view files in the same way as windows ?
Different way of number batch view (sort files numerically)?
Re: different way of number batch view ?
Yes, in the Browser select View > Sort by > Name in place of Name (not numeric)cyan wrote:Example : If I have files :
Is there a way to make XnView MP view files in the same way as Windows ?
Thank you
- Moderator
Re: Different way of number batch view (sort files numerical
Naming of sorting
I wonder why the naming in XnView Classic and XnView MP and the order of the menu items differs:
XnView Classic:
Name
Name (numeric)
XnView MP:
Name
Name (not numeric)
Default sort order
Sorting by Name (numeric) isn't default for XnView MP. And sorting by Name (numeric) should be default on both XnView Classic and XnView MP.
XnView Classic:
Name
Name (numeric)
XnView MP:
Name
Name (not numeric)
Default sort order
- Moderator
In XnView 0.84 beta 1 the default is Name (numeric), now.
But: The naming between XnView Classic and XnView MP is still inconsistent.
I'd suggest for both XnView Classic and XnView MP:
Name
Name (not numeric)
This means that XnView Classic needs to be changed.
Name
Name (not numeric)
- Moderator
Fixed in beta 4:
Default is "Name" and label says just "Name" while there is also "Name (not numeric)".
