Dear user,
XnView 2.37 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
____ 2.34 Changelog
Delete doesn't work on view mode
Charset in treeview - http://newsgroup.xnview.com/viewtopic.p ... 0&p=127128
Bevel settings - http://newsgroup.xnview.com/viewtopic.p ... 4&p=126724
Sharpen in Resize dialog - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32008
PNG icc profile checking - http://newsgroup.xnview.com/viewtopic.php?f=36&p=127277
alpha channel not copied in clipboard from browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32034
Colors & checksum in Overwrite dialog - http://newsgroup.xnview.com/viewtopic.p ... 6&p=127412
LibPNG 1.6.18
SqlLite 3.8.11.1
NConvert # in filename - http://newsgroup.xnview.com/viewtopic.p ... 2&p=127142
____ 2.33 Changelog
'Use extension' setting - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31619
LIBIMAGEQUANT on 256 colors image - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31567
Long filename - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31586
Clear out of bounds - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31604
Saving in Webp remove 1st pixel
Del during selection - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31760
On some jpeg, EXIF can't be rewritten
____ 2.32 Changelog
User plugin & check extension - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31403
Find similar don't find duplicates
Sharpen thumbnails - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31351
gs subfolder checked - http://newsgroup.xnview.com/viewtopic.p ... 2&p=124739
Customized data/time variables broken - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31367
Batch convert use estimated jpeg quality - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31398
____ 2.31 Changelog
Enlarge zoom quality
____ 2.30 Changelog
NConvert: -embedded_jpeg to extract embedded jpeg - http://newsgroup.xnview.com/viewtopic.p ... 7&p=124337
NConvert: Placeholder for EXIF date modified&date taken in output filename - http://newsgroup.xnview.com/viewtopic.php?f=57&t=29936
$EXIF:DateModified[date format] $EXIF:DateTaken[date format]
NConvert: Extension not forced lowercase - http://newsgroup.xnview.com/viewtopic.php?f=57&t=30294
NConvert: saturation from XnConvert
New addon for upload on ImageShack/Imgur - http://newsgroup.xnview.com/viewtopic.php?f=35&t=25014
Pdf issue - http://newsgroup.xnview.com/viewtopic.php?f=57&t=31292
Rename dialog move top/bottom - http://newsgroup.xnview.com/viewtopic.php?f=34&t=23924
Export dialog remember last folder - http://newsgroup.xnview.com/viewtopic.php?f=34&t=15352
Rotate EXIF orientation only process needed files - http://newsgroup.xnview.com/viewtopic.p ... 4&p=124316
BPG format read support - http://newsgroup.xnview.com/viewtopic.php?f=79&t=31040
File information overlay after reopen - http://newsgroup.xnview.com/viewtopic.php?f=36&t=28540
Placeholder use part of text - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30984
[x-], [x-y], [-y], [x]
Option>Settings>File list>Misc>Exif date used to sort
LockZoom & fullscreen - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31140
GIF Loop Slideshow & Quick slideshow - http://newsgroup.xnview.com/viewtopic.php?f=35&t=29154, http://newsgroup.xnview.com/viewtopic.php?f=36&t=7880
LibQuant for colors reduction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31063
Filter by image & disabled extension - http://newsgroup.xnview.com/viewtopic.p ... 2&p=122226
Alpha channel & enlarge resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30682
Similar files: now you can add files as reference - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30601
Sharpen view - http://newsgroup.xnview.com/viewtopic.p ... 9&p=121277
Change timestamp - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30930
XnShellEx: resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31004
Video gallery only first file used - http://newsgroup.xnview.com/viewtopic.php?f=36&t=23036
Convert Font script - http://newsgroup.xnview.com/viewtopic.php?f=36&t=1332
Non image filename not shown in statusbar - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31018
Similar dialog, use extension in filename - http://newsgroup.xnview.com/viewtopic.php?f=56&t=30908
Back key settting - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30746
PAM format added - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30741
Thumbnail sharpen value - http://newsgroup.xnview.com/viewtopic.php?f=34&t=13348
Autodeskew in toolbar - http://newsgroup.xnview.com/viewtopic.p ... 5&p=119267
Screen dpi on Win 7/8 - http://newsgroup.xnview.com/viewtopic.p ... 6&p=119294
Pause/Play animated gif - http://newsgroup.xnview.com/viewtopic.p ... 2&p=119543
Color picker and greyscale picture - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30215
"Rename all" in OVerwrite dialog - http://newsgroup.xnview.com/viewtopic.php?f=56&t=29151
DDS L8 format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=25507
Settings saved after changes - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30866
Clear in batch convert
Previous focused tab in IPTC dialog - http://newsgroup.xnview.com/viewtopic.php?f=35&t=27902
[IPTC]/PreviousTab
XnView 2.37
XnView 2.37
- Moderator & Librarian
Re: XnView 2.37
VirusTotal scan results (including checksums):
Re: XnView 2.37
Is there any explanation anywhere for the change "Change timestamp and video"? I searched in the forum and the documentation, but didn't find anything.
- Moderator
Re: XnView 2.37
In the above changelog there are links to the topics. From what I can see "Change timestamp and video" is fixed in 2.30 and discussed in topic "Change Timestamp" time calculation bug.Dan Harkless wrote:Is there any explanation anywhere for the change "Change timestamp and video"? I searched in the forum and the documentation, but didn't find anything.
Re: XnView 2.37
Guten tag, Helmut. Yes, I noticed the links to the topics by some of the changelog entries; the lack of one next to "Change timestamp and video" is why I posed my question. The 2.30-related topic you link to doesn't say anything about videos, but perhaps it is indeed talking about the right issue, and the 2.37 changelog entry should have read "Fix 'Change Timestamp' DST bug on videos".
- Moderator
Re: XnView 2.37
Yes, I also guess the problem described in topic "Change Timestamp" & DST was addressed in this change. Perhaps Pierre can confirm this.Dan Harkless wrote:Guten tag, Helmut. Yes, I noticed the links to the topics by some of the changelog entries; the lack of one next to "Change timestamp and video" is why I posed my question. The 2.30-related topic you link to doesn't say anything about videos, but perhaps it is indeed talking about the right issue, and the 2.37 changelog entry should have read "Fix 'Change Timestamp' DST bug on videos".
Re: XnView 2.37
Horrible bug.
I have a mouse wheel is used for "the next / previous file." In version 2.37, if the files in the directory are HiDPI files, then the mouse wheel "forget" about it and change the scale. Mode often changes itself in a single session. I returned to version 2.36, which is all right.
(Windows XP)
(Windows XP)
- Moderator
Re: XnView 2.37
This indeed severe bug has been reported before and will be fixed in XnView 2.37.1, soon.Ayou Gaf wrote:Horrible bug.
(Windows XP)
Related topics:
2.37: Mousewheel navigation: Zooming instead of navigating
2.37: Mouse wheel zooms instead of navigating
Re: XnView 2.37
Sounds like this bug: “Change Timestamps fails after file without exif date” (reported in 2014)Dan Harkless wrote:Is there any explanation anywhere for the change "Change timestamp and video"? I searched in the forum and the documentation, but didn't find anything.
