0.83: Slash instead of backslash in copied filename and path
geoffm
Post by geoffm »
When using the Edit > Copy to clipboard > Filename and path function, the path is copied with / instead of \ which makes the path unusable in Windows. I would often use this feature to quickly get the image file in a "browse" dialog to upload it to a website or insert it in a document, however I cannot use this in XnView I have to use Windows Explorer.
geoffm
Re: slash used instead of backslash in filename and path cop
Post by geoffm »
In case others have had problems with this, I just found a handy workaround: adding file:/// before the path makes it usable in Windows dialogs. At least in Windows 10.
Moderator & Librarian
Bug confirmed for browse mode :bugconfirmed:
See also: copy path but got the wrong slash.
i can't confirm this problem, in browser 'Copy to clipboard>selected filename and path' use \
Sorry, bug confirmed for browse view mode.
See Issue 980 for details.
Re: 0.83: Slash instead of backslash in copied filename and
This problem is supposed to be fixed in XnView MP 0.84 beta 1. Could you please try and confirm the bug fix, geoffm?
Just did a test and it worked fine for me. :arrow:Closed.
@geoffm: Please holler if you still have problems with 0.84 beta 4 or higher.
