disable reading all files meta data in browser mode
xephu
Post by xephu »
Hello, how to disable reading all files meta data in a directory in browser mode?
Thanks for helping :)
Re: disable reading all files meta data in browser mode
do you means XMP/IPTC? or file header?
xephu
Post by xephu »
I mean file header.
xephu wrote:I mean file header.
no, XnView need the picture information
xephu
Post by xephu »
Why? For what?
xephu wrote:Why? For what?
for labels, for detail view, to be able to sort, ...
xephu
Post by xephu »
No problem. Those functions could then be disabled. And detailed view column could be empty. Thats how I wanted it.
xephu wrote:No problem. Those functions could then be disabled. And detailed view column could be empty. Thats how I wanted it.
you don't use browser?
xephu
Post by xephu »
Yes, but those informations aren't interesting for me. Those only slows down (eg in networks) and I want to use those informations in the the browser (detailed view) as a bookmark. They can show me in directories with lots of pictures, which pictures I have seen, when those meta data are only be loaded when opening the picture or when selecting it in the browser to load the thumbnail. This way of functioning would help me a lot.
pangwolin
Post by pangwolin »
If disabling reading most meta data would speed up XnView, I think that would be a good option to have.
Browsing a lot of files tends to make the program lag a lot in some cases.
