When new file is opened, several older files appear [Fixed]
yanpol
Post by yanpol »
I use XnView MP because of its session saving. I really need this feature and I think it is the only software that offers it. I just have one weird problem and I don't know if it's a bug or a feature that I should disable. I'll try to describe it. Say that I open a saved session of 3 pictures from 3 different folders. Let's say they are the first picture in their folder. Then I browse the next pictures in these folders. After a while I need to work with a new picture from a different folder. When the new picture appears, all the original pictures (first in their folder) of the saved session open too. So instead of four pictures, I now have seven tabs open. And because I usually work with many tabs, this gets very confusing. Am I doing something wrong? I really would appreciate your help.
Re: When a new file is opened, several older files appear to
really strange, could you send me your xnview.ini? On windows? How do you open the fourth picture file?
yanpol
Post by yanpol »
Yes, Windows 10. I double click the picture inside its folder.
yanpol wrote:Yes, Windows 10. I double click the picture inside its folder.
with a clean .ini are you able to reproduce?
yanpol
Post by yanpol »
I am afraid I don't have the technical knowledge for what you are asking. I" ll try to give a detailed description.
I open a saved session with 3 tabs.
Tab1 -> Picture 01 from Folder A
Tab2 -> Picture 01 from folder B
Tab 3-> Picture 01 from folder C.
I browse the pictures of the folders A and B by pressing "Next file", so now the open tabs are:
Tab1 -> Picture 20 from Folder A
Tab2 -> Picture 20 from folder B
Now I open a new picture from a folder D. The tab with the new picture opens, but at the same time two new tabs open with picture 01 from Folder A and picture 01 from Folder B, from what I understand these are the saved tabs from the folders that I subsequently browsed. Picture 01 from Folder C, which I didn't browse, didn't reappear. So now the following tabs are open:
Tab 4 -> Picture 01 from Folder A
Tab 5-> Picture 01 from Folder B
Tab 6 -> Picture 01 from Folder D
That happens everytime a new tab opens. Imagine the chaos when I work with 20 tabs. I find it unlikely that it is a setting, but if it is, plase tell me which.And if I can help in any other way, please ask me.
i can't reproduce, in Settings>Integration>Paths, click on 'Open config file location', in this folder, you have a xnview.ini
please send me it, and rename it
yanpol
Post by yanpol »
Ok, I"ll do. I didn't undestand the last part. Rename the .ini? When (before I send it or after) and to what?
yanpol wrote:I didn't undestand the last part. Rename the .ini? When (before I send it or after) and to what?
I think Pierre is asking you to send him the existing xnview.ini file and to then rename that file on your computer which I think will result in a new, clean .ini file being created...
yanpol
Post by yanpol »
I tried to send you the .ini attached to this post but I got the message "The extension ini is not allowed." In what other way can I send it?
Moderator & Librarian
yanpol wrote:I tried to send you the .ini attached to this post but I got the message "The extension ini is not allowed." In what other way can I send it?
Please upload your INI as an archive (ZIP, RAR, 7-Zip).
yanpol
Post by yanpol »
Ok, here is the ini file.
XNVIEWMPINI.zip
(22 Bytes) Downloaded 89 times
yanpol wrote:Ok, here is the ini file.
there is a problem with your zip file...
yanpol
Post by yanpol »
I made a rar file. I think it's ok.
xnview.rar
(4.09 KiB) Downloaded 90 times
yanpol wrote:I made a rar file. I think it's ok.
ok, thanks. How do you open the fourth picture file?
yanpol
Post by yanpol »
By double clicking the picture file, inside its windows explorer folder.
