the <Search results> are linked with wrong files
Locked
jens116
Post by jens116 »
It is very nice that the handling of the <search results> is revised in Version 1.80.2 but unfortunately there is a defect in the linking of the thumbnails.
If you make a double-click on an <search result>-thumbnail to show the picture in the view mode a wrong picture is displayed.
Re: the <Search results> are linked with wrong files
jens116 wrote:It is very nice that the handling of the <search results> is revised in Version 1.80.2 but unfortunately there is a defect in the linking of the thumbnails.
Yes, right a bug :-(
It works here ---
:arrow: xnview
:) Hello Pierre !
- Under Win 98 SE, I get the right images from the thumb-nails of a Search result … in the preview only! Open in View by 2-click or ENTER, they are wrong… while open by the button of the tool-bar the pics in view are right !
:mrgreen: Kind regards,
Fixed, but---
:) Hi Pierre !
- This seems fixed in 1.80.3 under Win 98 SE, thanks !
- But at the first test after upgrade to 1.80.3, I'd a lot of thumb-nails for animated GIFs which didn't display an image, but only the icon of the file-type…
- At the second try, all has worked fine… Image
Dreamer
Re: Fixed, but---
Post by Dreamer »
Clo wrote::) Hi Pierre !
OK, I'll close this one soon, you can start a new topic, if needed :wink:
Locked
