0.82b3: Crash while other app handle files
Bugs that are confirmed but cannot be fixed for some reasons.
Nutznieser
Post by Nutznieser »
I work with XnView and Hugin (Panorama photo stitcher). With Hugin you can create panorama pictures.
If you combine pictures with Hugin, it automatically generate/remove some temporary tif-files in the current folder. Have opened the same folder in XnView, leads to crash it. In my opinion it happens if XnView scans the folder to new files. But the files are handled (create/delete) from Hugin in the same time. :?:
Yesterday I sent a crash report about that problem. Maybe that help, too, to find the bug.
I used XnView MP 0.82 beta 3
HarryH!
Re: Crash while other app handle files
Nutznieser wrote: Yesterday I sent a crash report about that problem. Maybe that help, too, to find the bug.
please try to send a crash report with 0.81?
Nutznieser
xnview wrote: please try to send a crash report with 0.81?
I tried it, but I can't reproduce it with 0.81. But with all higher beta versions it comes to a crash.
HarryH!
please send me the .dmp file by mail?
Nutznieser
xnview wrote: please send me the .dmp file by mail?
I did it right now :D
And I recognized the problem appears only if I have many files in the working folder (e.g. currently there were ~400 files). Otherwise the crash happens very seldom. So, with the big folder I could reproduce the crash also with 0.81 version and I sent you the report in the normal way (with crash reporter), too.
Thanks for your efforts!
HarryH!
Nutznieser
In version 0.81 beta 5 the bug was fixed. But now, in version 0.82 it is present again. :(
HarryH!
Nutznieser wrote:In version 0.81 beta 5 the bug was fixed. But now, in version 0.82 it is present again. :(
i have not fixed it in beta 5 :o
Nutznieser
But, you sent me the following post to my private email address for trying its:
yes the crash occurs in TIFF reader, please try this one
http://www.xnview.com/beta/XnViewMP-win-x64-beta5.zip
And in this version it seemed to be working.
HarryH!
oh yes the crash in TIFF, it's fixed like beta 5, strange that you have again a crash. Could you send me the dmp?
Nutznieser
xnview wrote:oh yes the crash in TIFF, it's fixed like beta 5, strange that you have again a crash. Could you send me the dmp?
Here is the crash report... is zipped.
My folder contains about 400 jpeg-files. If I start creating the panorama with Hugin, XnView do crashing at scanning the folder, because of the temporary tiff files. (maybe?)
b2e52445-4563-4650-86f3-7bbbcd235143.zip
Crash report
(127.08 KiB) Downloaded 196 times
HarryH!
ok, thanks
Re: 0.82b3: Crash while other app handle files
@Pierre: What is the status of this problem?
Related topic:
- Linux: 100% CPU consumption when using Hugin
helmut wrote:@Pierre: What is the status of this problem?
Related topic:
yes it's the same problem, seems to happened sometimes
Technical solution seems to be difficult (see other topic http://newsgroup.xnview.com/viewtopic.php?t=32918)
:arrow: Postponed
