opening with default windows viewer instead of xnview viewer
Bugs that are confirmed but cannot be fixed for some reasons.
harkonen
Post by harkonen »
Don't know if this is a feature or issue. From xmp Version 0.79 x64 (Mar 22 2016) in windows 10 pro 64, when opening files, if the file has not been categorized by xmp (see attachment in grey rows), it will directly open the file in a windows default viewer instead of using internal xmp viewer. Once the file has been categorized (yellow rows), then will it open it using xmp viewer.
Re: opening with default windows viewer instead of xnview vi
yes known issue because i don't know yet that file is an image...
xnview wrote:yes known issue because i don't know yet that file is an image...
@Pierre: Is there anything you can do about this, Pierre? If not, let's move this one to "Postponed".
currently no
