Rotate based on EXIF
Hacker
Post by Hacker »
Is it possible to use NConvert to rotate JPEGs (and their embedded thumbnails) based on their EXIF orientation flag (and then reset the flag, keep the timestamp and trim unused pixels - just like in the lossless rotate dialog)?
TIA
Roman
Re: Rotate based on EXIF
Hacker wrote:Hi,
No, but i'll add it
Hacker
Post by Hacker »
:D Thanks!
Roman
mrQQ
Post by mrQQ »
i can relate to this aswell - would be GREAT addition!
Post by Guest »
Is this command implemented yet? If so, what's the command line option for it?
Anonymous wrote:Is this command implemented yet? If so, what's the command line option for it?
No not yet implemented...
Post by Guest »
What kind of bounty would it take to see that implemented? I'd certainly throw in some money to see that happen. Or should I write a little python script or something that would decide which way to rotate based on exif data?
Gregg L.
Post by Guest »
BTW, jhead.exe can do autorotate, so I place it in front nconvert in scripts.
Gregg Lind
This request is listed in the Global request and suggestion list, already. I also think that this is an important feature and recommend to implement this in the next release.
nah0y
Post by nah0y »
Hello!
Sorry to reply on a so old thread...
Just wanted to know if this has been implemented yet? I can't find this anywhere so I guess it hasn't, but we never know :)
Thanks!
nah0y wrote: Just wanted to know if this has been implemented yet? I can't find this anywhere so I guess it hasn't, but we never know :)
yes
-jpegtrans exif
