Dear user,
XnView 2.36 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
____ 2.34 Changelog
Delete doesn't work on view mode
Charset in treeview - http://newsgroup.xnview.com/viewtopic.p ... 0&p=127128
Bevel settings - http://newsgroup.xnview.com/viewtopic.p ... 4&p=126724
Sharpen in Resize dialog - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32008
PNG icc profile checking - http://newsgroup.xnview.com/viewtopic.php?f=36&p=127277
alpha channel not copied in clipboard from browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32034
Colors & checksum in Overwrite dialog - http://newsgroup.xnview.com/viewtopic.p ... 6&p=127412
LibPNG 1.6.18
SqlLite 3.8.11.1
NConvert # in filename - http://newsgroup.xnview.com/viewtopic.p ... 2&p=127142
____ 2.33 Changelog
'Use extension' setting - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31619
LIBIMAGEQUANT on 256 colors image - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31567
Long filename - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31586
Clear out of bounds - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31604
Saving in Webp remove 1st pixel
Del during selection - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31760
On some jpeg, EXIF can't be rewritten
____ 2.32 Changelog
User plugin & check extension - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31403
Find similar don't find duplicates
Sharpen thumbnails - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31351
gs subfolder checked - http://newsgroup.xnview.com/viewtopic.p ... 2&p=124739
Customized data/time variables broken - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31367
Batch convert use estimated jpeg quality - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31398
____ 2.31 Changelog
Enlarge zoom quality
____ 2.30 Changelog
NConvert: -embedded_jpeg to extract embedded jpeg - http://newsgroup.xnview.com/viewtopic.p ... 7&p=124337
NConvert: Placeholder for EXIF date modified&date taken in output filename - http://newsgroup.xnview.com/viewtopic.php?f=57&t=29936
$EXIF:DateModified[date format] $EXIF:DateTaken[date format]
NConvert: Extension not forced lowercase - http://newsgroup.xnview.com/viewtopic.php?f=57&t=30294
NConvert: saturation from XnConvert
New addon for upload on ImageShack/Imgur - http://newsgroup.xnview.com/viewtopic.php?f=35&t=25014
Pdf issue - http://newsgroup.xnview.com/viewtopic.php?f=57&t=31292
Rename dialog move top/bottom - http://newsgroup.xnview.com/viewtopic.php?f=34&t=23924
Export dialog remember last folder - http://newsgroup.xnview.com/viewtopic.php?f=34&t=15352
Rotate EXIF orientation only process needed files - http://newsgroup.xnview.com/viewtopic.p ... 4&p=124316
BPG format read support - http://newsgroup.xnview.com/viewtopic.php?f=79&t=31040
File information overlay after reopen - http://newsgroup.xnview.com/viewtopic.php?f=36&t=28540
Placeholder use part of text - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30984
[x-], [x-y], [-y], [x]
Option>Settings>File list>Misc>Exif date used to sort
LockZoom & fullscreen - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31140
GIF Loop Slideshow & Quick slideshow - http://newsgroup.xnview.com/viewtopic.php?f=35&t=29154, http://newsgroup.xnview.com/viewtopic.php?f=36&t=7880
LibQuant for colors reduction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31063
Filter by image & disabled extension - http://newsgroup.xnview.com/viewtopic.p ... 2&p=122226
Alpha channel & enlarge resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30682
Similar files: now you can add files as reference - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30601
Sharpen view - http://newsgroup.xnview.com/viewtopic.p ... 9&p=121277
Change timestamp - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30930
XnShellEx: resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31004
Video gallery only first file used - http://newsgroup.xnview.com/viewtopic.php?f=36&t=23036
Convert Font script - http://newsgroup.xnview.com/viewtopic.php?f=36&t=1332
Non image filename not shown in statusbar - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31018
Similar dialog, use extension in filename - http://newsgroup.xnview.com/viewtopic.php?f=56&t=30908
Back key settting - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30746
PAM format added - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30741
Thumbnail sharpen value - http://newsgroup.xnview.com/viewtopic.php?f=34&t=13348
Autodeskew in toolbar - http://newsgroup.xnview.com/viewtopic.p ... 5&p=119267
Screen dpi on Win 7/8 - http://newsgroup.xnview.com/viewtopic.p ... 6&p=119294
Pause/Play animated gif - http://newsgroup.xnview.com/viewtopic.p ... 2&p=119543
Color picker and greyscale picture - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30215
"Rename all" in OVerwrite dialog - http://newsgroup.xnview.com/viewtopic.php?f=56&t=29151
DDS L8 format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=25507
Settings saved after changes - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30866
Clear in batch convert
Previous focused tab in IPTC dialog - http://newsgroup.xnview.com/viewtopic.php?f=35&t=27902
[IPTC]/PreviousTab
XnView 2.36
XnView 2.36
- Moderator & Librarian
Re: XnView 2.36
Thanks, Pierre!
WEBSITE REQUEST: Add Hash info and Torrent download support
Package | Size | CRC32 | MD5 | SHA1
XnView-win-small.zip | 4'227'568 | a4c387f6 | 5626e4bf3670cd47d2ce58952be49a80 | 70da8528179c00f8428a3a15d23aed88ce2bce9b
XnView-win-small.exe | 3'025'944 | fcd1e5c4 | 5fcf0b497d874960c3abd2137fbdd19d | 79ed00cd24b077dbc08da2a106f593f3c42d5635
XnView-win.zip | 7'323'183 | 8caca566 | c15767e04e8451c420bae9938dc333ae | 4bc034be4e0794d8902728ca480018ed33ce7792
XnView-win.exe | 5'105'152 | aa54f192 | 8c50657be7ca919c4b7b666c3cbcbb78 | f961d3a4532f08507e9ed7edaccbf05ac29c250d
XnView-win-en.exe | 5'105'152 | aa54f192 | 8c50657be7ca919c4b7b666c3cbcbb78 | f961d3a4532f08507e9ed7edaccbf05ac29c250d
XnView-win-fr.exe | 5'105'152 | aa54f192 | 8c50657be7ca919c4b7b666c3cbcbb78 | f961d3a4532f08507e9ed7edaccbf05ac29c250d
XnView-win-de.exe | 5'105'152 | aa54f192 | 8c50657be7ca919c4b7b666c3cbcbb78 | f961d3a4532f08507e9ed7edaccbf05ac29c250d
XnView-win-full.zip | 23'567'724 | a1fb9976 | d763937f2dce8dfc8e64bb12a1e6251d | 62cf7c46c844030368c1ca4f1e311c3190b6949e
XnView-win-full.exe | 18'593'216 | dda72e89 | e5d123eefbd61289193ab6b122ac861f | 12906d1b7a911644987d2d80a855353a001bc289
XnView-win-full-fr.exe | 18'593'216 | dda72e89 | e5d123eefbd61289193ab6b122ac861f | 12906d1b7a911644987d2d80a855353a001bc289
XnView-win-full-de.exe | 18'593'216 | dda72e89 | e5d123eefbd61289193ab6b122ac861f | 12906d1b7a911644987d2d80a855353a001bc289
Re: XnView 2.36
Please change the "Changelog"-button at http://www.xnview.com/en/xnview/ to current version 2.36.xnview wrote:...XnView 2.36 for Windows is available. ...
