Error choosing Twain-Import Device
Rudi99
Post by Rudi99 »
I have 2 USB devices, USB-Webcamm and USB-Scanner. Even if i chose the USB-Scanner, XnView always takes the USB-Webcam when importing. But i wanted the scanner to be imported...
Can anyone reproduce this error? (I hope, it isn't a FEATURE...)
Re: Error choosing Twain-Import Device
Rudi99 wrote:I have 2 USB devices, USB-Webcamm and USB-Scanner. Even if i chose the USB-Scanner, XnView always takes the USB-Webcam when importing. But i wanted the scanner to be imported...
Even if you choose the other by "select twain source"?
Post by Guest »
Ok, I#ve tried again with 1.80.2, here the results:
In "File - Select Twain Source" is select the USB-Scanner.
Then in "File - Aquire" it NOW corrrectly selects him and the Twain-Window opens.
And in "File - Aquire from Scanner or Camera" it takes the Webcam, correctly (WIA not TWAIN).
Seems to be fixed, have you changed something here since 1.80.0 ??
Anonymous wrote:Ok, I#ve tried again with 1.80.2, here the results:
No
