Add/Edit EXIF Title and Description
ACEkin
Post by ACEkin »
Is it possible using XnView MP to add or change the title (and possibly description) field(s) of a JPEG file? I have looked at the properties which only display EXIF and other data but could not find a way to add or modify the title field. Any direction will be much appreciated.
Thank you.
Re: Add/Edit EXIF Title and Description
currently you can't modify exif meta
ACEkin
Post by ACEkin »
Thank you Pierre for the quick reply. It would be a welcome feature if a few fields could be edited. I will have to find another solution to my problem.
Cemal
Mannimanaste
Post by Mannimanaste »
Hi ACEkin,
the solution can be the classic version from XnView.
There you can change some of the EXIF-Informations, for example the orientation-tag:
ACEkin
Post by ACEkin »
Thank you Mannimanste for your suggestion, I will take a look as needed.
