[Fixed] 0.76.1 Bug: Custom Sort
Erixx haxx
Post by Erixx haxx »
I'm not sure if this is a bug or not, but while in custom sort you can only move 1 file around at a time.
Open xnviewmp, Enter folder with lot of pictures
Set view to, Thumbs+labels
Set sort to, Custom
Highlite 3-4 picturess by, Shift+left click or control+left click, or click+ drag
Now try to drag files to the top or bottom of browser.
Will not work.
If you only select 1 file, then it works as wanted. this makes for long process of try to manually reorder photos.
Win7x64 pro
xnviewmp v0.76.1
Re: 0.76.1 Bug: Custom Sort
See Issue 780 for details.
Erixx haxx
Digging up old issues I see.
A Huge Thank you for this.
xnview wrote:See Issue 780 for details.
I really, really Than you. :D :D
Re: [Fixed] 0.76.1 Bug: Custom Sort
@Erixx haxx: Your previous post means that you can confirm the bug fix?
Erixx haxx
helmut wrote:@Erixx haxx: Your previous post means that you can confirm the bug fix?
Yes, this is fixed, I use it all the time now..
Thanks
Tom25
Post by Tom25 »
We can make custom sort when we are in the window of a folder, but we can't make custom sort when we are in an Album. If sort photos dragging them, and display another album ou another folder, and then come back to the Album we sorted, it come back to its original sort.
