Moderators: helmut , XnTriq , xnview
Moderator & Librarian
Posts: 6512 Joined: Sun Sep 25, 2005 3:00 am
Post
by XnTriq » Mon Aug 31, 2015 11:45 pm
Mock-up
Green background indicates an exact match, red means… Well, you get the idea
PS: I also like
custom fields !
Posts: 46252 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Tue Sep 01, 2015 4:39 am
perhaps the font color in red/green only??
Post
by XnTriq » Tue Sep 01, 2015 7:00 pm
xnview wrote: perhaps the font color in red/green only??
That would be great, yes
File size in bytes (if T ools » O ptions... » File List » Misc. » Use always bytes for filesize is activated)
Timestamp including seconds
Optional checksum calculation
Do you think this could be incorporated into the dialog for
cmd_Compare , too?
Post
by xnview » Wed Sep 02, 2015 10:53 am
or perhaps simply red when values are different?
Post
by XnTriq » Thu Sep 03, 2015 11:00 pm
xnview wrote: or perhaps simply red when values are different?
At least for the checksum, I would prefer both (red & green).
Screenshots:
thibaud
Posts: 274 Joined: Sat Dec 02, 2006 12:41 am
Post
by thibaud » Sat Sep 05, 2015 1:40 pm
good point.
a single color to indicate the error is what I would do too.
don't ask the user to process more information than needed and keep the ui consistent.
I'm not sure how relevant these md5 check app are in that regard.
Post
by XnTriq » Thu Sep 10, 2015 9:45 pm
Whoot! Implemented in version 2.34
obelisk
Posts: 479 Joined: Fri Jan 09, 2009 9:54 am
Post
by obelisk » Thu Sep 10, 2015 11:04 pm
great work!
Post
by XnTriq » Thu Sep 10, 2015 11:45 pm
As mentioned in a previous post, Use always bytes for filesize (T ools » O ptions... » File List » Misc. ) should also take effect in the replace dialog, IMO.
To prevent the 32-digit MD5 hash from being truncated, the right column of Replace and With could be moved a little farther to the left.
Making use of PathCompactPathEx (or PathCompactPath ?) would improve the display of truncated pathnames : X:\Eeny…Moe\Destination\ vs. X:\EenyMeenyMinyMoe\Des
Although the files are not identical, XnView displays the same checksum for Replace (X:\Test\Destination\placeholder.jpg ) as for With (X:\Test\Source\placeholder.jpg ).
Replace: X:\Test\DST\placeholder.jpg (Exif orientation 1) = 3126b90e4c94b4a19380baa7e567c273
With: X:\Test\SRC\placeholder.jpg (Exif orientation 2) = aa00fea6eb31e37090fd21f21fa123b6
p127537.zip
placeholder_dst.jpg + placeholder_src.jpg (334.99 KiB) Downloaded 291 times
Karl02
Posts: 134 Joined: Mon Sep 03, 2007 1:00 pm
Post
by Karl02 » Mon Sep 14, 2015 6:26 am
For symmetry, there should also be functions for "Replace all" and "Skip all". But to avoid too many buttons, there should be a checkbox "[ ] Apply to all".
-- Karl
Post
by xnview » Wed Sep 16, 2015 10:37 am
it's edit textfield, so no need to shorten filename
Post
by XnTriq » Wed Sep 16, 2015 3:00 pm
Don't tell me you're rejecting my valuable programming tips
But seriously, I see what you mean: Users can select the text (
Directory &
Name ) with the cursor.
Post
by xnview » Thu Sep 17, 2015 7:20 am
Post
by XnTriq » Tue Jan 05, 2016 2:45 pm
XnTriq wrote: Although the files are not identical, XnView displays the same checksum for
Replace (
With (
p127537.zip
This bug hasn't been fixed in the latest release (v2.35).
Post
by XnTriq » Tue Dec 06, 2016 9:30 pm
The fix isn't listed in the changelog but since v2.36 this feature works as expected. Thank you, Pierre!
