Error output folder name
kosho
Post by kosho »
With the command :
nconvert -o "C:\#test\jpg\7V1A3881.JPG" -out jpeg -resize 1920 1280  -opthuff -q 90 -i "C:\#test\7V1A3881.JPG"
the result :
Conversion of C:\#test\7V1A3881.JPG into C:\1test\jpg\7V1A3881.JPG OK
Why the output folder is changed to C:\1test?
Re: Error output folder name
kosho wrote:With the command :
the result :
In the NConvert help file '#' is defined as a numeric enumerator:
Options :
-o filename       : Output filename
              Use # to specify position of numeric enumerator
              Use % to specify source filename
              Use $ to specify full source pathname
              Use $$ to specify source folder name
I don't know if there is a way to 'escape' that interpretation, but doubling as required to escape some characters in a Windows batch file would be interpreted as a two-character numeric enumerator...
Edit -- Two possibly relevant posts:
Re: output to folders with "#"
Filenames with % character
I don't know if the proposal in the first was implemented, and the second suggests that it might be worth trying '##' contrary to my thought above?
Does anyone know if '#' can be escaped when used in an output file name?
if i add $# to escape #??
xnview wrote:if i add $# to escape #??
Whatever you think would be best... :D
I don't know if there are any conventions for escape characters; a character that would be unlikely to be used in a file name might be a good choice (such as ^ or ~ perhaps?) or even a character that would be illegal in a (Windows) filename such as '>' if that is technically possible??
Consistentcy with any other escape use cases in NConvert would be desirable.
Other suggestions welcome...
As '#' is a numeric enumerator that may, if I understand correctly, be included in code as '#' '##' '###' etc, any escape notation should if possible work for any representation...
As for the escape notation to be used, that is really outside my experience (I never expected even to use the command line... :wink: ) but I have presented some thoughts above that may or may not make sense.
kosho
Post by kosho »
It worked in version :
** NCONVERT v5.50 (c) 1991-2009 Pierre-E Gougelet (Sep 16 2009/15:20:46) **
And it is replace # with 1 when I tried the new version.
# is a numeric enumerator for file name, not for folder.
kosho wrote: And it is replace # with 1 when I tried the new version.
i've added $# for next version. But is it needed to have # for folder name??
gautxori
Post by gautxori »
Can xnview make a note of this in nconvert help?
