This topic is for listing truncated labels in the on-screen texts of XnView MP.
Please report labels that are not fully displayed and truncated by mentioning
- XnView version and your language (e.g. Dutch, French)
- truncated label (in your language)
- English label
Thank you for helping to improve XnView!
Truncated labels [All languages]
Re: Truncated labels [All languages]
Version 0.72 - Language German - OS Linux/Ubuntu
Dialog: Confirmation request for overwrite at save image
Sample:
Regards
Dietmar
Sample:
Regards
Dietmar
Version 0.91 beta1 - Language German - Windows 10 64bit
File > Export: "Set transparency color..."
File > Export: Buttons "Exportieren..." and "Aktualisieren..." (Labels are complete but buttons are truncated on the left side due to dialog's size)
if you grow the dialog a little, all is ok?helmut wrote: Fri Aug 31, 2018 9:48 pm Version 0.91 beta1 - Language German - Windows 10 64bit
Correct.xnview wrote: Sat Sep 01, 2018 2:52 pmif you grow the dialog a little, all is ok?helmut wrote: Fri Aug 31, 2018 9:48 pm Version 0.91 beta1 - Language German - Windows 10 64bit
Version 0.99.5 - Language German - Windows 10 64bit
Default widths of dialogs "Canvas resize" and "Resize" are a bit too narrow and therefore some entries in drop download list with predefined formats are truncated.
E.g. instead it says "Photo 4x6 i... (10x15cm)" instead of "Photo 4x6 inches (10x15cm)"
Strange i can't reproduce, the dialog width is always resized, no ellipsishelmut wrote: Fri Jan 07, 2022 4:23 pm Default widths of dialogs "Canvas resize" and "Resize" are a bit too narrow and therefore some entries in drop download list with predefined formats are truncated.
Field for timestamp is not large enough, see topic Change Timestamp : hidden digits
