no thumbnails for video :(
FlyAway
Post by FlyAway »
Hi :)
I do not understand why the thumbnails for video don't work. I also installed the K-Lite Codec Pack but without success :(
I see the thumb of a few videos, (4 in 300) video that I have downloaded from internet/youtube
Can you help me please? :|
Re: no thumbnails for video :(
avi, mov??
FlyAway
Post by FlyAway »
avi and mp4. And is strange becouse I see correctly the thumbnails in win explorer of those files (Win 8.1 64bit)
The only extension that work is wmv
FlyAway
Post by FlyAway »
I did an experiment, I have copy a bit of video and have brought them to a friend who has Win 8.1 32bit (my is 64bit)- We have downloaded Xnview and open it whit the default setting but he have my same problem :(
FlyAway wrote:I did an experiment, I have copy a bit of video and have brought them to a friend who has Win 8.1 32bit (my is 64bit)- We have downloaded Xnview and open it whit the default setting but he have my same problem :(
could you send me a video file that doesn't work?
FlyAway
Post by FlyAway »
yes sure thanks, where?
edit
I'm upload on rapidgator.net 3 video without preview and one that have it, Tomorrow I write the url here. Thanks
edit
http://rg.to/file/1af1d9f38466bfbfcc766 ... o.rar.html
:wink:
ok, i have the same problem. Thumbnails can't be extracted with standard windows api, strange...
FlyAway
Post by FlyAway »
xnview wrote:ok, i have the same problem. Thumbnails can't be extracted with standard windows api, strange...
It is strange to you, then for me it is a real mystery :mrgreen:
I hope this problem will be solved in the next version because it does not seem a little problem, I have sent only small video but the problem also with almost all films :( :( :(
thank you for your, usual, availability
perhaps a codec format, i have no problem with my videos
FlyAway
Post by FlyAway »
boh :( my video will drain from everywhere and many have no thumbnails and I have send you an avi, one mp4 and a flv. Not only a strange weird video.
Xnview probably not recognize new formats / codecs that are used now
BaldrickTheGreat
Post by BaldrickTheGreat »
Same problem here (Windows Vista). I converted some .mov videoclips I took with my Canon Ixus camera to .mp4 using Handbrake (default settings). Installed K-Lite Codec Pack. Mp4:s can be played but no thumbnails are generated by XnView unless I rename the files to .m4v but then they can´t be played.
hh11
Post by hh11 »
same problem :
correct thumbnails in Windows 7 (64bits) and no thumbnails in Xnview for mp4
note :
- with Xnview 2.25 : no thumbnails for .mp4 AND .mov also
- with Xnview 2.33 : thumbnails OK for .mov :D (without touch .ini) BUT no thumbnails for .mp4
Bon courage Pierre et merci par avance
for mp4, please try to edit xnview.ini, and change
VideoFormat=3
hh11
Post by hh11 »
Thank you for your answer but
1/ I don't understand "Code: Tout sélectionner"
2/ In xnview.ini, I can't find "VideoFormat"
"video" is found only in these items :
[Browser]
FitVideo=0
VideoFrame=1
VideoPlayBar=1
[Slide]
FitSmallVideo=0
[VideoCapture]
[View]
VideoFitAll=0
VideoLoop=0
VideoPlayBar=1
3/ So, In what part of xnview.ini may I add "VideoFormat=3" please ?
in [Browser] section add VideoFormat=3
