Hi all,
I wrote a BPG plugin for XnView (32-bit only) which supports both Read & Write feature.
You can find more information in:
https://github.com/leavinel/BPG-Plugins
To download, go to the releases tab.
BPG read/write plugin
Re: BPG read/write plugin
Great, thanks!
Perhaps it will be good to have a x64bits version for XnViewMP
Hi Pierre,
Thanks for your reply.
Is XnViewMP plugin SDK available?
I only found XnView plugin SDK.
the plugin for XnView is compatible with XnViewMPLeavinel wrote: Thanks for your reply.
Yes, please - it would be great to have an updated encoder (current is 0.9.6) and x64 support!xnview wrote:Perhaps it will be good to have a x64bits version for XnViewMP
Hi Leavinel,Leavinel wrote:Hi all,
Thank you for this plugin, i have searched many image viewer that support bpg and finally found this. I see your plugin is quite old, is it discontinued? It would be great if it support 64-bit because my XnView crash when encoding large image (RAM usage for encoding large image is more than 2GB). Also please update to support 8-bit image for converting mangas.
Hi all,
Now x64 & greyscale support are available.
Also, I replaced libbpg's internal YUV<->RGB converter (with my buggy hand-written SSE code) to libswscale. It should be faster and stable now.
BPG plugin 0.0.0.5
BPG plugin 0.0.0.5
Where can I find "BPG-xnview-XXXX.7z" on https://github.com/leavinel/BPG-Plugins ?
Thank you.
Thank you.
The release pageEuphoria wrote:Where can I find "BPG-xnview-XXXX.7z" on https://github.com/leavinel/BPG-Plugins ?
Thank you.
https://github.com/leavinel/BPG-Plugins/releases
