paths in the visual style XnView
user100
Post by user100 »
It's not really a bug but you check.
These black contours have appeared in recent versions XnView.
OS XP.
before it was so
before it was so
black contours in recent versions
Moderator & Librarian
Re: paths in the visual style XnView
I've noticed this too and do't like it either. It seems as if the changes were made after repeated requests by a single user.
user100
Post by user100 »
you do so as it was before?
user100 wrote:you do so as it was before?
Sorry, I don't understand.
Are you looking for a way to undo or suppress these changes? I don't think there's a setting for this.
user100
Post by user100 »
in the next version of your program you fix the interface?
Or you will not change anything in the code?
Now use v2.23 02/10/2014 , This is the latest version without these distortions. Do not update, wait when you return the previous/old look.
ps
Do not know how else to write that would be more understandable
This translates google translator so hard to write so that it is not distorted.
Could you write a French language but there will probably be even more errors. :)
My apologies for the late reply, user100. I missed your last post :-|
Yesterday we've had a related request: Toolbar border / line
Perhaps we can convince Pierre to add an option for restoring the old look.
XnTriq wrote:Perhaps we can convince Pierre to add an option for restoring the old look.
Thanks for reverting to the 3D look, Pierre.
v2.33 vs. v2.34
v2.33 vs. v2.34
