ShellEx: Embedded Thumbnail for JPEGs
Lesmo16
Post by Lesmo16 »
I like to suggest an additonal special size entry for JPEGs in the options of the ShellEx.
Entry should be: "Embedded Thumbnail"
As you can imagine, it should show the unmodified size of the embedded thumbnail. :wink:
Everyone who believes in telekinesis, raise my hand!
Re: ShellEx: Additional size option for JPEGs
Lesmo16 wrote:I like to suggest an additonal special size entry for JPEGs in the options of the ShellEx.
Ok, i'll add it but if there is no embedded?
Lesmo16
Post by Lesmo16 »
Then the entry is greyed.
Perhaps better is "Use embedded thumbnail if exist", no?
Lesmo16
Post by Lesmo16 »
xnview wrote:
Lesmo16 wrote:
xnview wrote: Ok, i'll add it but if there is no embedded?
OK :)
xnview wrote:Perhaps better is "Use embedded thumbnail if exist", no?
Sounds good to me, too, but I think the English is not correct. "Use embedded thumbnail if available" sounds better to me.
What do English native speakers mean?
Dreamer
Post by Dreamer »
Added. Thanks Pierre.
Closed.
