I would likt to report an error: When renaming (single file, I didn't check for multiple files) to an existing file, the wanted renamed file is deleted after showing a message that there's already an existing file.
I would like to suggest also to change the tabulation order for the Batch Rename window (see attachment) from the red circle (textbox name template?) to directly the blue circle (textbox start) when pressing TAB button because I use the keyboard often and when renaming over and over, it's a little frustrating to press many times TAB to go to the textbox start number (I even suggest Insert and Duplicate TAB buttons to be after textbox Step).
Thank you very much
File deleted when renaming to existing file
- Attachments
- Batch Rename.png (32.88 KiB) Viewed 1064 times
