2.30 crashes and corrupt display of images saved by MPC-HC
Gingerbread Guy
Post by Gingerbread Guy »
Windows 7 x64 SP1 with the latest updates
XnView 2.30
This issue is new in this version. 2.25 works fine. For your convenience, I'm attaching a sample image, so you can skip the steps to reproduce 1–3.
1. Start MPC-HC x64 1.7.8.
2. Open a video file.
3. Open the File menu and choose Save Thumbnails. Set the width as less than your screen resolution, then save the file.
4. In the XnView Options, View category, View tab, set the following:
  • Auto Image Size: Fit image to window, all.
  • High Quality Zoom: check both "Reduce" and "Enlarge".
5. Browse to the folder with the sample image and double-click it to try to open it in a new tab. The rendering is corrupt: it's monochrome and striped all over.
6. Right-click the image in the new tab and choose Fullscreen. XnView usually crashes at this point. Other times, it goes into full screen mode but crashes when right-clicking and choosing Auto image size, then Fit to window width.
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	xnview.exe
  Application Version:	2.30.0.0
  Application Timestamp:	54e59f3b
  Fault Module Name:	xnview.exe
  Fault Module Version:	2.30.0.0
  Fault Module Timestamp:	54e59f3b
  Exception Code:	c0000005
  Exception Offset:	001e21d1
  OS Version:	6.1.7601.2.1.0.256.1
  Locale ID:	1033
  Additional Information 1:	0a9e
  Additional Information 2:	0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:	0a9e
  Additional Information 4:	0a9e372d3b4ad19135b953a78882e789
Re: 2.30 crashes and corrupt display of images saved by MPC-
The problem comes from "Enlarge"
Gingerbread Guy
Resolved in 2.31. Thank you very much.
