"Must fixes" for next release
RazR83
Re: "Must fixes" for next release
Post by RazR83 »
Tpau wrote:
xnview wrote:I can't reproduce
Ok - but I can reproduce it:
start with selecting a large image in thumbs view - doubleclick -> fullscreen display (OK so far)
doubleclick on image - single image is shown (instead of thumbs only view like when using "enter"!)
doubleclick again - thumbs are shown again
doubleclick another image -> opens in fullscreen
doubleclick on image -> single image with window controls is shown, controls are duplicated
Also reproduce this bug on 1.96.2 :o
Will be fix in next release?..
Thanks.
RazR83 wrote: Also reproduce this bug on 1.96.2 :o
Yes, if i can reproduce it...
RazR83
Post by RazR83 »
xnview wrote:Yes, if i can reproduce it...
Hm-m, may be another bug, but very similar and easy to reproduce (1.96.2 + Vista SP2 x86):
1. Tools - Options - Keyboard/Mouse - select one of the actions (for example double clikc left mouse button) to "Browser > Fullscreen > Viewer"
2. Do this action on picture from browser.
3. So, what we can see...
RazR83 wrote:Hm-m, may be another bug, but very similar and easy to reproduce (1.96.2 + Vista SP2 x86):
If you use "Browser > Viewer", no problem?
RazR83
Post by RazR83 »
Yep, no problem!
Bug only for action "Browser > Fullscreen > Viewer" :?
DreXor
Post by DreXor »
if not patched yet, the issue of corrupting videos when generating thumbs
DreXor wrote:if not patched yet, the issue of corrupting videos when generating thumbs
XnView corrupt your video???
Karl02
Post by Karl02 »
This is a real showstopper bug:
- 1.94.2: Option "Use different position/size for browser
Furthermore, before adding any other features, the custom sorting of thumbnails should be added, even if it would be difficult. It has been requested many times and is a basic feature for every image organiser:
- Moving files within folder (sort by custom order)
RazR83
Post by RazR83 »
Still present this bug in 1.97.2 on Win7 x86:
  1. Tools - Options - Interface - "Add 'Exit' to context menus" must be checked
  2. Open an image (view mode) and Zoom+
  3. Right click and then left click on "Exit"...
If "Ctrl+Q" - no bug! :shock:
bucky
Post by bucky »
This bug should qualify as a "must fix" because it involves image data loss. Multiple users have confirmed the bug.
1. In Viewer mode, press "ctrl+s" to save a large image (e.g. 10+ megapixel jpeg)
2. Click "yes" to overwrite
3. Quickly press "enter" during the save to go to Browser mode
4. Open the image again, it will be corrupted.
http://newsgroup.xnview.com/viewtopic.php?f=36&t=20059
Ralf
TIFF file crashes XnView 1.97.6 (and GFL SDK too)
Post by Ralf »
marsh
Post by marsh »
rvveen
Post by rvveen »
Brooktrout viewing/codec problem
I can't use commandline conversion because of this problem
jo2h2
Post by jo2h2 »
For me In Fullscreen mode new images are not opened "from outside" is very annoying.
Tested it again with latest version:
  • When I set >Startup - "Fullscreen - Edit"< and double-clicking on an image in Windows Explorer, that image is displayed fine in Fullscreen mode - but leaving this image opened, just switching Alt-Tab to Windows Explorer, double-clicking on a different image in Windows Explorer XnView somehow switches its window and then XnView completely closes down. So either I have to quit XnView before opening the next image or have to click on that other image a 2nd time after the XnView "auto-close" ...
  • When I set >Startup - "Fullscreen - Browser"< and double-clicking on an image in Windows Explorer, that image is displayed fine in Fullscreen mode - but leaving this image opened, just switching Alt-Tab to Windows Explorer, double-clicking on a different image in Windows Explorer XnView hangs. After a while pressing ESC I can close XnView, but it should not hang :-)
  • OK, when I set >Startup - "Normal"< and double-clicking on an image in Windows Explorer, that image is displayed fine in normal mode. Leaving this image opened, just switching Alt-Tab to Windows Explorer, double-clicking on a different image in Windows Explorer XnView switches to that other image in normal mode - fine - but I would like to use Fullscreen mode :-)
  • And when I set >Startup - "Fullscreen" - Edit< plus >General / Operations - >>not<< Only one Instance< and double-clicking on an image in Windows Explorer, that image is displayed fine in Fullscreen mode. Leaving this image opened, just switching Alt-Tab to Windows Explorer, double-clicking on a different image in Windows Explorer XnView opens again in Fullscreen mode - fine - but I only want one instance to run - I don't want to close all those XnView instances manually later ...
So in >Startup - "Normal"< it works, in Fullscreen it has two bugs - and as these bugs are now quiet old I would really love to have them fixed - this would be like an "early Christmas gift" :-)
Thanks a lot !!!
