"Must fixes" for next release
There's more and more XnView users and more and more specific bugs are found and reported. This is very good, much appreciated and helps to improve XnView's quality!
With all the defects reported it's important that the serious issues which limit functionality are fixed with high priority.
Indicators for "must fixes":
- General Protection fault (GPF)
- Memory leak
- Important funcationality cannot be used at all.
- The users' images are endangered (changed, deleted, ...)
If you think that a bug is very serious and a must fix, simply place a post here and with a link to the original post. If it is not obvious why your defect is a "must fix", please provide some explanation.
Please do NOT report new bugs as reply to this topic, instead please start a new topic.
Thank you and Greetings,
Pierre / Helmut
Lightspeed
Xnview browser crashes in Win 95 (all versions after 1.82.4)
Post by Lightspeed »
I think this bug was first reported here:
http://newsgroup.xnview.com/viewtopic.php?t=11744
I understand that this is probably not a high priority since few people still use Windows 95. I'm just wondering if the intention still exists to eventually fix this, or if W95 users should consider 1.82.4 as the last working version for them. If so, perhaps it should be noted on your download page. I know 1.82.4 is still available from your server at:
http://download2.xnview.com/old_version ... %201.82.4/
Long live XnView :)
Re: Xnview browser crashes in Win 95 (all versions after 1.8
Lightspeed wrote:I think this bug was first reported here:
Long live XnView :)
Yes, very good point. Thanks for focusing us and Pierre on the Win 95 issue, Lightspeed.
Screen Capture?
Post by Guest »
This may not be a bug, but an improvement in Screen Capture functionality... to allow capturing portion of the screen, not the entire screen or windows.
Perry
thibaud
Post by thibaud »
Dreamer
Post by Dreamer »
Path info saved in ini file even if history is disabled
Perhaps it doesn't look so important, but it's very annoying if more users are using the same computer / account...
Dreamer
ckit
Post by ckit »
File Associations do NOT work with Vista SP1 x64 and have to be fixed!
Long-drink bug---
:arrow: All
Helmut wrote
… Important funcationality cannot be used at all.
• It's the case with a bug when copying on a 32 BPP PNG and some others.
That bug has been reported prior in a JohnFredC's friend thread HERE, then in a French thread I started
in which the last today message shows that it isn't fixed yet in 1.95.3; that can be seen on this IMAGE
(comments are translated on) of a clipboard viewer…
• I can't use XnView anymore for copy, that's very annoying. The only workaround is to paste in M$ Paint,
then copy in it and paste in the GFIE or else, as long as there is no transparency,
because Paint ignores it and thus it's black
:mrgreen: KR
RickS
Cannot copy file from Gimp to XnView
Post by RickS »
http://newsgroup.xnview.com/viewtopic.php?t=16151
This is a "must fix" for any of us that want to copy a file from Gimp to take advantage of XnView's ability to launch Adobe Photoshop plugins (something in which Gimp is woefully inadequate). There was no problem doing this through v.1.94.2.
Dreamer
Re: "Must fixes" for next release
Post by Dreamer »
Dreamer
Tpau
Post by Tpau »
Regarding latest XnViewMediaDetector
please see: http://newsgroup.xnview.com/viewtopic.php?f=36&t=17870
Regarding latest Xnview:
Check freeing of system ressources after closing fullscreen images directly to the thumnails - when repeating that procedure there's a multitude of fake MDI-system-controls (min,max,close) loaded - obviously left-overs from previous full-screen display (just one image allowed mode).
Tpau wrote:Check freeing of system ressources after closing fullscreen images directly to the thumnails - when repeating that procedure there's a multitude of fake MDI-system-controls (min,max,close) loaded - obviously left-overs from previous full-screen display (just one image allowed mode).
?? Which OS do you have?
Tpau
Post by Tpau »
W2k with all possible updates
I can't reproduce
Tpau
Post by Tpau »
xnview wrote:I can't reproduce
Ok - but I can reproduce it:
start with selecting a large image in thumbs view - doubleclick -> fullscreen display (OK so far)
doubleclick on image - single image is shown (instead of thumbs only view like when using "enter"!)
doubleclick again - thumbs are shown again
doubleclick another image -> opens in fullscreen
doubleclick on image -> single image with window controls is shown, controls are duplicated
does not happen when: opening small images, could be related to sparse GDI ressources.
happened with 4000x3000 pixel images
XNview-Version: 1.96.1
Screenshot (open in extra window for full width):
