XnView creates restricted folder names in windows
weiv
Post by weiv »
I created a folder in XnView and gave it a name 'con'. Turned out this is one of the restricted folder/file name in windows and XnView cannot open it. If you try to delete it, Windows will prompt an error saying the folder cannot be found.
The only way you can delete that folder is to open up the CMD console and remove it with special cmd (http://java.ittoolbox.com/groups/techni ... der-848496)
Please fix this problem so people don't accidentally create restricted folder names.
list of restricted names,
CON, PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, and LPT9
