0.69 shortcut bugs and intermittent opening into other vwr
harkonen
Post by harkonen »
The shortcuts still do not work properly. Using layout #5, in the bottom pane, when calling some of the shortcuts eg rename using F2, as custom shortcut, there is no reaction. 2nd I have zoner photo studio 15, periodically instead of opening a file eg .jpg internally with it's viewer, sometimes the .jpg will open up in zoner.
Re: 0.69 shortcut bugs and intermittent opening into other v
harkonen wrote:The shortcuts still do not work properly. Using layout #5, in the bottom pane, when calling some of the shortcuts eg rename using F2, as custom shortcut, there is no reaction.
Never?? Even if you try another shortcut...
The .jpg show his thumbnails??
JohnFredC
Post by JohnFredC »
harkonen wrote:I have zoner photo studio 15, periodically instead of opening a file eg .jpg internally with it's viewer, sometimes the .jpg will open up in zoner.
This happens to me too. It seems as if sometimes MP acts according to the Windows app-association rules and, instead of opening the double-clicked browser thumb's file in an MP image tab (as the user expects), delivers the file outside XnView to the associated app instead.
I cannot reproduce this, but it does happen from time to time.
John
