Use custom selection <C> hotkey doesn't work
Locked
Dreamer
Post by Dreamer »
When I choose "Custom" through the context menu, it works fine.
Dreamer
Doesn't work…
:) Hello !
- Confirmed, if I set xnView in English, I can get a saved custom selection only like you say, when the Edit Menu >> ... is open, while there is not any "C" hotkey for this entry.
- If I set XnView in French, the shortcut doesn't work, neither directlty with "C" (closed menu) nor when the menu is open…
- It works only by clicking the entry … or adding a hotkey in the French DLL ;)
:mrgreen: Kind regards,
Dreamer
Post by Dreamer »
Another bug(?) and maybe also reason why <C> key doesn't work - it's used for Custom selection size and ratio.
Re: Use custom selection <C> hotkey doesn't work
Dreamer wrote:When I choose "Custom" through the context menu, it works fine.
right :bugconfirmed:
This bug keeps annoying me. Would be nice to see it fixed.
helmut wrote:This bug keeps annoying me. Would be nice to see it fixed.
ok
Locked
