Web template variables for thumbnail dimensions
Moderator & Librarian
Most – if not all – of XnView's web templates are built with tables. The downside of this approach is that the thumbnail pages have a fixed number of columns.
I made a few “fluid” gallery templates years ago for my own personal use. They're based on lists or DIVs and have an integrated JavaScript lightbox.
Unfortunately, I always have to manually edit XnView's HTML output, because there currently is no way to retrieve the values of Width and Height from Create » Web Page... » Thumbnail. (#THUMB_WIDTH# & #THUMB_HEIGHT# apparently only work inside #THUMB_ROW_START# & #THUMB_ROW_END# or #THUMB_START# & #THUMB_END# or #THUMB2_START# and #THUMB2_END#.)
I'm requesting two new variables: #THUMB_WIDTH_MAX# and #THUMB_HEIGHT_MAX#
Re: Web template variables for thumbnail dimensions
please send me a template?
Here's a barebones example:
[color=green]thumbs.html[/color] wrote:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title> #TITLE#</title>
<style type="text/css">
ul {
list-style: none;
li {
margin: 0.5em;
padding: 0.5em;
position: relative;
width: 128px; /* thumbnail width */
height: 128px; /* thumbnail height */
float: left;
text-align: center;
border: 1px solid black;
a {
display: table-cell;
text-align: center;
vertical-align: middle;
img {
</style>
<!--[if IE]>
a {
width: 130px; /* thumbnail width plus 2 pixels */
height: 130px; /* thumbnail height plus 2 pixels */
display: block;
span {
height: 100%;
display: inline-block;
</style>
<![endif]-->
</head>
<body>
<ul>
#THUMB2_START#
<li><a href="#ORG_SUBPATH#/#PIC_LINK#"><span></span><img src="#THUMB_LINK#" width="#THUMB_WIDTH#" height="#THUMB_HEIGHT#" alt="#THUMB_ALT#"></a></li>
#THUMB2_END#
</ul>
</body>
</html>
I can't get this one to work:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
body {
text-align: center;
div#Gallery {
margin: 0 auto;
width: 90%;
div.Box {
margin: 1em;
width: 144px; /* thumbnail width plus 16 pixels */
display: -moz-inline-box;
-moz-box-orient: vertical;
vertical-align: top;
div.Thumbnail {
height: 144px; /* thumbnail height plus 16 pixels */
div.Thumbnail * {
div.Thumbnail img {
div.Caption {
margin-top: 0.5em;
font-size: 0.76em;
</style>
<!--[if lt IE 8]>
div.Box {
display: inline;
div.Thumbnail {
display: block;
div.Thumbnail span {
width: 1px;
height: 100%;
</style>
<![endif]-->
</head>
<body>
<h1>#HEADER#</h1>
<div id="Gallery">
#THUMB2_START#
<div class="Box">
<div class="Thumbnail"><span></span><a href="#ORG_SUBPATH#/#PIC_LINK#"><img src="#THUMB_LINK#" width="#THUMB_WIDTH#" height="#THUMB_HEIGHT#" alt="#THUMB_ALT#" /></a></div>
<div class="Caption">#THUMB_TEXT#</div>
</div>
#THUMB2_END#
</div>
<p>#PAGE_GENERATED#</p>
</body>
</html>
XnTriq wrote:I can't get this one to work:
With this one, #THUMB_WIDTH# & #THUMB_HEIGHT# are not replaced?? I've tried and it works...
xnview wrote:With this one, #THUMB_WIDTH# & #THUMB_HEIGHT# are not replaced?? I've tried and it works...
OK, I found the problem :mrgreen:
If the template (thumb.html) is saved with LF instead of CR+LF line breaks, output is faulty:
<head>
<title> Title</title>
body {
text-align: center;
div#Gallery {
margin: 0 auto;
width: 90%;
div.Box {
margin: 1em;
div.Thumbnail {
div.Thumbnail * {
div.Thumbnail img {
div.Caption {
margin-top: 0.5em;
font-size: 0.76em;
</style>
<!--[if lt IE 8]>
div.Box {
display: inline;
div.Thumbnail {
display: block;
width: 1px;
height: 100%;
</style>
<![endif]-->
</head>
<body>
<h1>Header</h1>
<div id="Gallery">
_START#
<div class="Box">
<div class="Thumbnail"><span></span><a href="original/landscape.jpg"><img src="thumb/t_landscape.jpg" width="128" height="96" alt="" /></a></div>
<div class="Caption">landscape.png</div>
</div>
_START#
<div class="Box">
<div class="Thumbnail"><span></span><a href="original/portrait.jpg"><img src="thumb/t_portrait.jpg" width="96" height="128" alt="" /></a></div>
<div class="Caption">portrait.png</div>
</div>
_START#
<div class="Box">
<div class="Thumbnail"><span></span><a href="original/square.jpg"><img src="thumb/t_square.jpg" width="128" height="128" alt="" /></a></div>
<div class="Caption">square.png</div>
</div>
</div>
<p>This page was generated by <a href="http://www.xnview.com">XnView</a></p>
</body>
</html>
XnTriq wrote: Do you see a chance for implementing an enhancement like this:
#THUMB_WIDTH_MAX# and #THUMB_HEIGHT_MAX# are the max of all thumbnails size?
xnview wrote:#THUMB_WIDTH_MAX# and #THUMB_HEIGHT_MAX# are the max of all thumbnails size?
Yes, I'm referring to the values for Width and Height as entered by the user in the Web page Create dialog.
Would it be very difficult to allow basic arithmetic operations like addition, subtraction, multiplication, division and percentage?
Thanks for adding #THUMB_WIDTH_MAX# and #THUMB_HEIGHT_MAX# in version 2.23, Pierre.
It seems that these variables are only “active” if placed in between #THUMB_START# & #THUMB_END# and #THUMB2_START# & #THUMB2_END#.
Could you please make them “globally” available (like #TITLE#) so that they can be used in the document's header for CSS and JS includes?
[color=green]\XnView\WebTemplate\Test\thumb.html[/color] wrote:
<head>
<title>#TITLE#</title>
<script type="text/javascript">
document.write("<style type=\"text/css\">" +
               "div.Box {" +
               "width: " + (#THUMB_WIDTH_MAX# + 16) + "px;" +
               "height: " + (#THUMB_HEIGHT_MAX# + 16) + "px;" +
               "</style>");
</script>
</head>
ok :)
xnview wrote:ok :)
:D Thanks!
I believe there's been a misunderstanding.
The current implementation of #THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# seems to return the values of Width & Height in Picture » Size maximum. Can you confirm this, Pierre?
I was referring to Width & Height of Thumbnail:
XnTriq wrote:Unfortunately, I always have to manually edit XnView's HTML output, because there currently is no way to retrieve the values of Width and Height from Create » Web Page... » Thumbnail.
right
XnTriq wrote:I believe there's been a misunderstanding.
Fixed in v2.35 :bugfixed:
19leunam93
Post by 19leunam93 »
Is it possible to share your “fluid” gallery templates you have created?
The default templates are all based on tables, which is outmoded in web-design...
Thanks
